Thread: error codes
    Oct 2010
    yorkshire
    Default error codes
    hi im getting an error code when i do the brake and accelerator trick its code 0014, ive booked it into vx and they said if they cant find an error using the diagnostics machine they will charge me for doing it
    if its showing on the self test will it defo show up on their machine?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    Oct 2010
    yorkshire
    yeah i know thats what the code says it is, i dont know what it means though!
    but really its if there reader will read it is what i want to know
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As long as you don't clear it with a code reader or unplug the battery it should be yes.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, is the spanner and car icon on or MIL on? Does the car drive oddly at all?
    If not, then it is probably a stored historic fault and will clear after a few days.
    Oct 2010
    yorkshire
    no theres no spanner, seems to drive ok but ive had the car about a month now and it hasnt cleared????????????
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    IMO, I wouldn't worry about it unless the car begins to drive oddly - down on power, fuel economy changes significantly.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You need someone with op-com, if the code is showing 'not present' clear it 7 it will be fine!, IF its showing 'present' DO NOT CLEAR THE FAULT!, This could prevent the car from starting!!, & may not restart until the problem is rectified!, & seeing as you're not 100% sure what exactly is 'the fault', this could cause you unnecessary headaches!.
  1. (error codes)
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2012, 20:07
  2. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  3. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  4. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  5. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
