Thread: engine drops below idle??1.9 cdti 150
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default engine drops below idle??1.9 cdti 150
    hi guys, my 08 car drops below idle when i either coast or dip the clutch in. mabe between 10 and 0 mph when slowing down. has any body had this problem with their car or know what may be causing it? got the car cheacked with vx they said nuthin wrong with it they said it may be the erg? but the car runs totaly fine apart from this problem the cars only done 31000 and i use it every day. im totaly baffled
    Oct 2010
    London
    Does the engine actually stop or hesitate etc?
    My old Astra's 1.7 used to dip to about 500rpm if I put the clutch in and coasted, but it recovered OK
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    My Corsa used to do some of this when it had a MAF problem. I can't remember what the best thing to clean it with was off the top of my head but some form of 100% alcohol that will evaporate. Maybe nail polish remover? Sure someone on here will know.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I am not sure I fully understand what you are saying.
    Are you saying that if you depress the clutch pedal (or knock into neutral) the engine revs go below what would normally be stationary idle? Or do you mean that if you watch the revs they stabilise at idle when you are moving and then drop to a lower idle speed when the vehicle stops?
    "Driven idle" speed will be higher than stationary idle - perfectly normal and correct
    Does the engine stumble or mis-fire or show any issues?
    Wales, UK
    Think what he means is, that when slowing down to stop, if you depress the clutch and coast to a halt, the enigne revs drop below idle, the engine slightly shudders untill the vehicle comes to a complete stop - where the engive revs increase to a normal idle.
    Ive experienced this before in mine. Not sure what it is though, definately does not effect the drivability, just a weired one I think !
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    The facelift 1.9CDTI has 'anti-stall' where the revs are held at the idle speed of about 800 rpm.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    hey guys thanks for ure input, Ste---"Are you saying that if you depress the clutch pedal (or knock into neutral) the engine revs go below what would normally be stationary idle? " ---this is it, like what mark 647 said the revs go back to normal when i stop, so iguess it is just a weird one :S. just want to get it sorted b4 the warranty finishes! the car dose do it alot but as i said no one found a problem and the car drives fine, i'm so baffled haha
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    oh ment to ask whats a MAF? lol
    Wales, UK
    Mass air flow sensor mate..
  1. Engine won't idle! Help!
    Last Post: 5th December 2010, 17:43
  2. engine idle on the 150 cdti
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 20:21
  3. engine on idle
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2009, 12:33
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. engine idle speed help
    By jaxouk in forum Engine & Drivetrain
    Last Post: 17th April 2008, 20:57
