Thread: lambda sensor
    Central Scotland
    Default lambda sensor
    Z18XE engine
    I was getting three fault codes all relating to 02 bank 1 sensor 1 failure. Car was running very lean to the point the plugs were white.
    Got a brand new genuine Bosch 02 sensor, cleared off fault codes and drove 30 miles. Now it's running rich....
    P0170 - Fuel Trim System Rich
    (11) - Present
    P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    (5A) - Not present
    P0704 - Clutch Switch Input Circuit Malfunction
    (05) - Not present
    P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)
    (04) - Present
    P0130 - O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    (11) - Not present
    P0130 - O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    (01) - Present
    P0030 - O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
    (08) - Present
    P1565 - Cruise Control Interface Malfunction
    (71) - Not present
    U2103 - CAN-Bus Node no Communication
    (70) - Not present
    The numbers in brackets - P0170 (11), as P0170 is a general code does anyone know or can list the additional (11) codes? Or a website where i can get specific info on them.
    Central Scotland
    Found the diagnostic I done just before I replaced the pre cat lambda -
    P0170 - Fuel Trim System Lean
    (12) - Not present
    (5A) - Not present
    (05) - Not present
    (04) - Present
    P0335 - Crankshaft Sensor Incorrect Signal
    (08) - Not present
    (11) - Not present
    (04) - Not present
    (08) - Not present
    P1405 - Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    (61) - Not present
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Did you check the wiring too? P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) would imply the wiring harness isn't making a good connection somewhere. Did you clean the O2 sensor electrical plug?
    Bristol
    Vehicle : CDTI 150
    Quote Originally Posted by Ste View Post
    The open cct heater fault code is still present. Have you also checked FE15 in the UEC. Its 10A and supplies the heater cct.
    Central Scotland
    Fuse ok, wiring visibly ok, connection clean.
    The fueling lean/rich may also be down to the fuel pump failing, which is being replaced tomorrow.
    Then I'll check autodata to get the wiring diagram and pin numbers ECM to 02 sensor and do a continuity test.
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
P0130 - O2 Sensor Circuit RangePerformance (Bank 1 Sensor 1) (08) - Present
