Results 1 to 10 of 16
Thread: Damn Vectra
    Sep 2009
    Glasgow
    Default Damn Vectra
    Ok, last few days i have noticed slight jerking at idle, sluggishness, and a drop in mpg from 45.4 - 43.4 ok not a big drop but this is the lowest mpg i have returned since owning the car, feel like there is a bigger lag before turbo kicks in as well, anyone any suggestions, off rest of week, so time to have a muck about, inletmanifold/dmf have been changed in the last 6 months, but not 100 % sure the egr was changed, can i phone uncle arnold and ask about job sheet. Also car rarely reaches 80-85 degrees and when heating is turned on quickly drops to around 70 degrees, new airfilter was installed last month and airbox mod has been done. Honestly getting sick of the problems, might trade her in.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Sounds like the EGR valve to me. If it went in for the manifold then imo they won't have changed the EGR valve.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Glasgow
    I would phone and ask if the EGR was changed it could be that for the power issue. Your diesel engine wont heat up to the temps you are used to as the winter draws in, diesels runs colder than petrols. You will also notice it takes longer for the heater to heat up in the morning lol.
    Sodding Typical on Sea
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Ayemy money would be on the EGR too.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Sounds like an EGR problem, sadly getting fed up of a 1.9 is a common issue...
    Sep 2009
    Glasgow
    was told it was recomended by vx to change egr along with manifold change, how easy is it to remove and clean it looks easy, and should i fit restricted gasget.
    Sep 2009
    Audley STAFFS
    IF Temp drops to 70 with heater fan on your stat/temp sender is faulty, this will cause a drop in performance and poor mpg, when the stat stuck open on mine mpg droped 6 mpg. but its a petrol.
    Regular Member Exclusive BV's Avatar
    West Midlands
    did,nt realise a faulty stat caused a drop in performance, the temp guage on my 1.8 does not move from the cold stop unless im stuck in traffic
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Exclusive BV View Post
    this time last year I NOTICED a drop in performance from my 1.8, then realised the temp guage would go up to 80 in traffic but drop on the open road to 70 which where it starts, the fuel,,, also a drop in mpg, As soon as I did the stat/ temp sender, all back to normal it now runs on 87 degrees and power back to normal, and good mpg. someone did explain why a power loss when running with a faulty stat but I forgot why rgds,, ANT.
    Sep 2009
    Glasgow
    can def confirm, car heats up to 80, 85 if sat in traffic for a while, but on open road even at 30 mph as when i turn heating on full within minutes it drops 2 70-65
  1. Damn i need both of these.....
    By signum_rob in forum General Motoring Chat
    Last Post: 25th June 2012, 08:20
  2. god damn it!!
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 10:59
  3. Damn Car!
    By Torque in forum Engine & Drivetrain
    Last Post: 21st February 2011, 19:06
  4. Damn...
    By spoons in forum General Chat
    Last Post: 23rd August 2008, 00:42
  5. Damn PVS........
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 17:48
