Thread: Lumpy Idle + 1Gal/PH
    Oct 2010
    London
    Default Lumpy Idle + 1Gal/PH
    Hi guys
    Second Q of the day, sorry to be such a pain!!
    I was coming back home earlier after being out for about 40 minutes in the car and when I stopped at a roundabout I could feel the engine idling 'lumpy', probably more pronounced by the autobox.
    It was quite bad, you could feel the car jolting, and when I parked up outside the house it was really bad in reverse (like you are not giving a petrol enough revs), and when I parked up I saw that the engine was using 1gal/per hour!!
    So I thought (after reading what I had on here) that the DPF could be up to some funny business, so I drove it back out (still lumpy), got to a nice stretch of NSL road and gave it a good old hoof, and after that it stopped?
    Was this the DPF causing this or is something else more sinister going on? No lights came up on the dash at all, and was not down on power...
    Cheers people
    (sorry to be such a pain!)
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Depends which model you have
    But sounds like like it was re-generating the DPF, classic symptoms for re-gen
    Oct 2010
    London
    Sorry keefy forgot to say - 1.9CDTi 150 Auto
    Have checked the number in the box on the chassis and I do have a DPF
    If it is classic DPF regen then I can live with that... thought something had gone wrong at first!!
    Can Tech2 turn the flashing of the glow-plug light back on so I know when it is being an arse?!
    Thanks dude
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    As yours is an auto it has a DPF, its the classic regen symptoms, nothing to worry about...
    Oct 2010
    London
    I was hoping that would be the answer - I had read the fuel economy goes through the floor but was not sure about the lumpy running.
    How often do they usually regen?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    lumpy runnign is probably due to the timing being off which is does during a regen.. Something Benny said to me about how it misfires on purpose for some reason...
    Oct 2010
    London
    Was doing some more reading on it here earlier, found out it puts another shot of diesel in on the exhaust stroke, which hits the cat on the DPF and heats it all up.
    Very interesting how it works - but ****** annoying! Wrecked my fuel economy drive
    Huddersfield
    Mine did exactly the same the other day. Identical symptoms! Mines also an auto estate 150 cdti.
    The extra fuel for to burn the soot off the filter is injected AFTER the combustion so it would make sense that the engine wouldn't run completely smooth, although I've never noticed anything major with mine. The extra 2 cylinders might make a difference though...
    Oct 2010
    London
    Quote Originally Posted by Penfold101 View Post
    Don't rub your 6-cylinderness in my face
  1. 2.0t edition 100 lumpy idle
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 4th January 2012, 17:02
  2. 3.2 lumpy idle update
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 9th August 2011, 14:59
  3. Lumpy idle on 2.2 Direct SRi
    By Palmo in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 18:53
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
