Thread: Elm 327 car diagnostic fault code reader
    Jan 2010
    glasgow
    Talking Elm 327 car diagnostic fault code reader
    as per title guys any 1 got 1? any used 1 or know some 1 that has 1? are they any good? rite i have op-com but im looking for a cheap code reader for my megane and the bay has the elm for about £16
    Jan 2010
    glasgow
    just found out the guy that i got my op-com off sells them so i may get 1 from him rite guys any 1 used 1? are they any good?
    Regular Member duncmill's Avatar
    Apr 2009
    manchester
    I’ve got one and it does what it says on the tin, although it was a bit fiddly to set the com port up
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Also got one. Good little bit of kit except it won't talk to my 2.2 DTi
    Engine : 1.9 CDTi
    What software do you use with them as I am also looking at getting one.
    Jan 2010
    glasgow
    hi lee depends what you want it for if its to use on a vauxhall you would be better off buying op-com im looking at getting the elm to use on a renault if its op-com your after pm me bud and i will give you the website where i got my op-com from
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If you do pick up one of the ELM interface boxes off Ebay, I always used PCM Scan. Was a brilliant bit of kit.
    http://www.palmerperformance.com/pro...scan/index.php
    Jan 2010
    glasgow
    hi cont1204 do you have a full working version ?
    Engine : 1.9 CDTi
    Its to use on non Vauxhall cars (I use Vaux-Com already)
    PCM Scan looks good but a bit pricey lol
  1. fault code reader?
    By andrewwelsh1958 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 09:55
  2. What fault code reader?
    By s2yob in forum The 'Off Topic' room
    Last Post: 25th July 2011, 13:43
  3. Fault Code Reader
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2010, 10:45
  4. Car diagnostic scanner code reader
    By s1nglef1sh in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2009, 19:33
  5. Car Diagnostic Code Reader / Scanner OBD2 CAN U581 2009
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
elm 27 wont talk to vectra c 2.2dti
