Thread: Wharrup?
    Regular Member influencd's Avatar
    Oct 2010
    Eversley
    Lightbulb Wharrup?
    Heya,
    Been lurking for a week or so now so I thought I'd say hello.
    I've got an '04 Vectra - 2.2 SRi DTi.
    Absolutely love it, though I've had a few problems so far and found this place as a result.
    I think the problems have been pretty common. Had to replace the wiper linkage as it was popping out and leaving me half wiperless at the most inappropriate times
    Most recently I had the first booster hose coming off the turbo develop a split. A bit of limp mode, black smoke and a repair bill later I was back on the road... only to have the next pipe in the chain go about three days later. There's a bit of residue oil in the system so I'm guess they've just come of age and got a bit weak.
    I ended up buying both remaining hoses (but silicone this time) off fleabay and fitting them myself. Apart from having a rear end as sooted as a chimney sweep's ballsack I'm back to normal and turbo'd up.
    I just had a K&N filter arrive this morning so I'm looking forward to getting that in along with doing the airbox mod at the same time. I'm also booked in for a major service at the stealers. Along with that 'm also going to be pulling out the EGR and boost valve for a clean next week for a cleanup...
    A few questions (maybe not the best place for them):
    Is it worth replacing the EGR gasket?
    I've got brake cleaner, will this be alright instead of carb cleaner?
    Is there anything else you'd do out of urgency to a 64k, 6 year old veccy that may help me get some of its youthfullness back?
    Awesome forum btw.
    Later days.
    Forum Moderator & Events Team davedrinks's Avatar
    Sep 2010
    Luton
    23 Post(s)
    Vehicle : Vectra Hatch
    Engine : 1.8VVTi 16v
    Mileage : circa 28K
    I'm sure someone will answer your questions before too long...because I can't!!!lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Welcome mate, excellent choice of engine btw
    I've had my EGR valve off 3 times since getting the car and haven't replaced the gasket yet. As long as it's in good condition there isn't any reason you can't re-use it.
    Brake cleaner will be fine although I soak my egr valve in diesel for a few hours first.
    With regards to doing more, you can remove the top inlet pipe and give it a good clean out as the oil/exhaust gasses combine to make a sludge in the pipe. The boost sensor is also in this pipe so give it a good clean too, don't touch the middle bit though (by the way the middle but should be yellow but is normally covered in oil)
    Mileage : 000
    Welcome to the site.
    Oct 2010
    Eversley
    Thanks for the feedback - I'll check that out!
    Regular Member leonvectrac's Avatar
    south shields
    welcome along
    Regular Member lewcdti's Avatar
    Oct 2010
    South Wales
    Sep 2010
    Hartlepool
    If your car is on 64k, I would seriously consider getting the timing belt / chain (Not sure which it is on a DTi) changed in the near future.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Welcome to vec-c m8 and to the south central region .
    It will be a chain on a 2.2 dti
