Thread: Fault code on Vectra
    May 2006
    scotland
    Angry Fault code on Vectra
    All,
    I have a 1.9 CDTI and noticed this morning that the trip in Diagnostic mode gave the value and this is a static value i.e. does not change so I assume a stored fault code:-
    STORE:- 0100 0000000008
    Does anyone know what this is? The STORE value was all zeroes a couple of weeks ago. This change does however coincide with strong exhaust fumes eminating from under the bonnet and filling the interior when sitting idling. I will check at weekend with my handheld code reader but me think this can be the start of much expense. Damm.
    I will also go to an exhaust outfit and ask if they could check the front flexi pipe but I doubt that is the cause as I can hear no exhaust blowing noises.
    Inlet manifold is original from 2004. ooh dear.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't know how you have got that number, what is 'diagnostic mode'?
    But anyway, if the 0100 is a fault code then it is
    P0100 Mass or Volume Air Flow Circuit Malfunction
    May 2006
    scotland
    Thanks.
    There is a thread on this site I saw a couple of years back on how to get into the Diagnostic mode. Basically, I have a trip and a CD30 (I think). If I have the radio on and press the BC button (I think it is BC but it is the button on top RH of volume dial) and keep it pressed for about twenty seconds, you hear a beep, that is you now in diagnostic mode. You can then traverse through a number of screens by using the scroll button (again I think on the steering).
    Jan 2010
    glasgow
    shame your in Kirkcaldy if you were closer to glasgow i would have put op-com on it for ya to see what it found
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If its the cdti 150, strong fumes while standing or moving slow!, Inlet manifold failure would be the first place to look.
  1. Vectra C (Z18XE) fault code
    By Alexander79 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2012, 19:46
  2. Vectra c 3ltr v6 fault code
    By crayon in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 11:58
  3. 2003 Vectra fault code??
    By mossy2432 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th January 2011, 18:52
  4. vectra c fault code
    By cavie in forum Engine & Drivetrain
    Last Post: 7th December 2010, 17:54
  5. Aftermarket fault Code Reader for 06 Vectra
    By pigdog in forum Engine & Drivetrain
    Last Post: 20th August 2007, 23:58
