Thread: How to fit fog lamps ls
    Regular Member spandy234's Avatar
    Oct 2010
    milton keynes (bucks)
    Vehicle : Vectra C facelift
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    Default How to fit fog lamps ls
    Hi was after some advice on fitting the front fogs i have just recieved ,is it possible to fit them without bumper removal ? i have the how2 on this so if i need to it shouldnt be a problem ,i am going to wire my own switch rather than the expensive tech2 session
    they are standard fogs not sri ,hope to get them in soon so any help is much appreciated . Thanks
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    It can be done, but its a *****! I would have taken my bumper off when I did mine but it would also have meant removing the number plate, stuck on with 3M double sided tape, and the number plate surrounds which are screwed into the crash bar behind the bumper so I choose not to take the bumper off. I did however have to unscrew the sides of the bumper and pull the out to help gain access to get the top screw fitted, It really would have been easier just removing the number plates and surrounds........... Did you get the small plastic clip which holds the top of the fog light into the front bumper?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    How long were the screws you used to put the number plate surrounds on
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Only about 3/4 to 1 inch mate. Wanted to make sure they wouldnt come off ina hurry as I had some **** try to steal my number plate surrounds in the past
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It can be done on a Pre-Facelift, but not on a facelift.
    I fitted my fogs with the bumper in place, but with the engine under-shield removed.
    Mine is a 2005 Pre-Facelift.
    Also mine has a non-programmable under hood module, and so it could not be programmed to take fogs.. I fitted mine in a slightly tidier method than that in the Armoured Farmour How 2.
    Regarding screws, just fit one way screws or anti-tamper screws..
    We fitted a pair of these screws and 7 strips of bumper fixture adhesive pads after our plates were stolen 18 months ago.
    No chance of getting them off now
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As per your PM, this is how I did mine,
    Firstly as you asked, yes, I just jacked the front of the car up and put it on axle stands.
    To fit the fogs themselves to the bumper, you literally just need two self tapping screws to fit each light in place...
    Available for pence from Vauxhall. Note though that the correct Vauxhall screws are torx / star headed, although a standard self tapping screw should fit nicely.
    THE ELECTRICS BIT
    1) Take a feed from the grey/green wire for the cigar lighter.
    Feed this to a switch
    2) from the other side of the switch, run a wire to the control pin of a relay
    3) Run an earth tag wire to the other relay control pin
    4) Then take a fused feed from your battery and run this to one of the "controlled" pins of the relay
    5) from the fourth leg of the relay, run your wires to the fog lights (live side).
    6) from the other pins of your foglights, run a feed to earth.
    See image at the bottom, for my wiring diagram..
    Note, I fitted my relay in the battery box
    THE FITTING BIT
    What I did was..
    1) Remove under engine tray.
    2) pop out / unclip the black plastic blanking trims from the bumper
    3) connect up the wiring to suit, if present , it will be connected to the loom for the temperature sensor plug at the base of the radiator grille.
    Check that the electrical side of thngs work, before fitting the fogs to the bumper.
    4) Attach each fog lamp to the bumper.(using self tappers) The screws will be quite tight into their holes.
    5) Clip in new black trim next to the fog lamp.
    Check that the lights still work as expected, before refitting the engine under tray, and lowering the car back onto the ground.
    This is from memory, but I believe that you should find this to be accurate.
    Oct 2010
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    cheers rob really helpful will have a crack at it when the miserable weather improves .
    Andy
    Nov 2009
    Southampton
    Quote Originally Posted by spandy234 View Post
    Can someone point me to the howto. I have a pretty bog standard vectra C with rear fogs and, having had a dipped beam bulb blow and it being a pain to change at the roadside figure fitting some fog lamps would be an ideal get home solution to make things easier
    Martin
  1. fog lamps
    By big john0 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 20:24
  2. fog lamps
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 21:51
  3. hid lamps
    By tonka2 in forum Styling
    Last Post: 17th June 2009, 21:37
  4. hid lamps
    Last Post: 4th June 2009, 19:12
  5. fog lamps
    By monkyspunky in forum Styling
    Last Post: 22nd February 2006, 19:09
