Thread: Removing the Radio / Stereo cage
    Oct 2010
    North East
    Default Removing the Radio / Stereo cage
    I am playing around with my facelift model car at the weekend and I will need access to the wiring for the park pilot switch (I am adding aftermarket parking sensors with a view to controlling them with a modified switch)
    When fitting the Parrot kit last weekend, I noticed that access for the wiring for the switch was restricted by the cage that holds in the head unit.
    Is it possible to remove and reinstall the cage or do I have to carry out micro-surgery on the wiring in the dash? Or is there anyway to unclip the connector plug to obtain some slack to adapt the wiring.
    Other suggestions would be welcomed
    Admin plasma's Avatar
    On the Forum
    314 Post(s)
    Engine : 150
    Mileage : 74000
    Yes you can remove the radio and cage... Just remember if your half-can bus you'll need to re-enter the radio code when you refit it..
    The connectors for the switches all sit on a moulded bit of plastic, Once the cage is removed you can see the two clips which hold the bank of connectors in...
    One little clip at the top and another at the bottom (the whole switch assembly runs vertical from the top button down to the bottom and has to be removed as one piece...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Mainly as Plasma said,
    however as your's is a facelift, then the radio code will not need to be re-entered.
    All facelift cars will have a full CAN audio system.
    Regular Member lewcdti's Avatar
    Oct 2010
    South Wales
    The cage was a bit of a mare to get out on mine (pre-facelift). After undoing the screw which is holding it in (on the back 'wall' of the cage) I had to bend the top and bottom a little inwards at the front before I could wiggle it free, then when you are ready to re-fit, they bend back into shape relatively easily. If I remember rightly on my cage, the front top/bottom centre part is where the join in the metal is, which makes the bend and 'bend-back' pretty straightforward to be honest. It may be a bit different on your facelift tho, best of luck!
    Dunstable
    When I did this on my facelift I removed the whole centre console which seems a faff, but I got to everything I needed to. Quite an easy job once you figure out what the pins do on the button. If you remove one of the resistors in the switch (not the one for the leds) it turns it into a normal push-to-make switch which can then control a latching relay unit, which then turns on the front sensors and the indicator light on the switch. That's what I did on mine
    Oct 2010
    North East
    Quote Originally Posted by Ademusic View Post
    That is exactly what I am looking to do, although, I am using a timer circuit rather than a latching relay.
    The sensors are now fitted, the rear bumper removal was an awkward job, my brother in law is a time served vehicle technician and even he was wincing when we were pulling the side fixings loose.
    Have you got any pointers on removing the entire centre console please?
  1. JVC radio cage
    By ropa83 in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2011, 19:46
  2. Single DIN Radio Cage
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2005, 20:51
vectra c radio removal
removing stereo cage
https:www.vectra-c.comforumshowthread.php121825-Removing-the-Radio-Stereo-cage
how to remove vauxhall vectra head unit
radio removal on vectra c
vectra c stereo removal
how to take out a vectra c sterio
how to remove radio from a vectra c 53 plate
remove radio cage vectra c
vectra c pre face lift how to remove radio
remove vectra stereo cage
how to remove a radio cage from a vectra
