Thread: Parkpilot Switch Pin Out Configuration
    Apr 2009
    Aalborg
    Question Parkpilot Switch Pin Out Configuration
    Does anyone know the Parkpilot pin configuration.
    I have 5 pins on the factory switch that I want to rewire to handle an aftermarket Parkpilot URF7 front & rear.
    There are two sets of pin:
    Pin 6
    Pin 5
    Pin 4
    Pin 2
    Pin 1
    I am guessing that 1 would be ground, 1 a feed for LED illumination, 1 for the switch - and maybe 2 for Canbus?
    Any help appreciated. TIA
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    2 ground
    5 dimming (light)
    6 supply voltage (goes to BCM and is controlled via that)
    1 park lamp switch signal
    Dont know what pin 4 is for....
    Apr 2009
    Aalborg
    Thanks Ken ... lightning fast
    Oct 2010
    North East
    Spookily I was going to ask the same question as my switch turned up today, I think it will need a little 'attention' before it will work how I want it to...
    I have opened up the switch housing, picture attached and I reckon the following is how I need to rewire/amend to switch on (via a timer circuit) the front sensors.
    Pin 1 = On LED feed
    Pin 2 = Dim LED feed
    Pin 4 = Neutral / Earth for LED
    Pin 5 = Will become return for switch
    Pin 6 = Feed for switch.
    I will be wiring Pin 1 to the output from the timer circuit and isolating any connections between Pins 4 & 5 so they can act independently
    (Sorry for the poor image quality)
    It seems a shame to have to butcher a £20 switch, but to get it to do as I wish, needs must. There are additional connections on the rear that will need cutting as well.
    I will try to take some photos of the adaptation of the switch, the timer circuit and wiring so that others can try to follow (assuming I can get it all to work this weekend...)
    Apr 2009
    Aalborg
    Sounds great will help me when I have to do the same, although as I am using the Parkpilot setup the functionality will work the same as the standard so the timer will not be needed.
    I don't know your setup but the standard parkpilot switch (3 pins, one for LED illumination, 1 Ground, 1 Switch) that came with my URF7 so I guess I don't need to butcher the OEM switch - all I need is the On/Off, LED On, LED dim.
    I haven't tested whether the BCM supplies 12V even if Parkpilot is not setup via Tech2 but I will test with a multimeter.
    My choice now is to whether I cut the pins of the switch and wire from the PCB or think about modding the connector in the frame as the wires will not be used, I will have to see how much play there is in the connector of whether the connector is reusable.
  1. Parkpilot. will the wiring be in??
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2012, 22:51
  2. For Sale: Switches Clearout - Alarm, Parkpilot, Traction Control & Sports Switch
    By awilson in forum Parts for sale
    Last Post: 21st September 2012, 11:20
  3. parkpilot
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 00:40
  4. Parkpilot
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 11:18
  5. VX Parkpilot
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 16:29
