Thread: chattering
    york
    Exclamation chattering
    well finally after months of just putting up with it think ive finally put the chattering in acceleration down to the crank shaft pulley/ vibration dampner pulley has anyone had probs with these or fitted one themselves
    http://cgi.ebay.co.uk/CRANKSHAFT-PUL...item5638c2cb8d
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    hi m8 i work in a dealer and have never changed a bottom pulley on a 1.9 what makes you think its that?
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    I've had mine replaced when i had the alternator replaced as there was a wee bit excessive play in it. I didnt want the outer piece flying upwards at high revs and sawing through the air con pipes etc.. My friend who is a mech advised me to het it replaced but hadnt came across the one on my 1.9.. It appeared to be held on with four small bolts, but when i got the new one back it had only one large bolt in the centre.. Mine looked like the rubber insert was coming away when you put pressure on it, but i cant see how that is clicking on your car
    Sep 2009
    Glasgow
    get the same noise
    york
    this is what the mechanic told me it would be after having belts off to change alternator the rubber middle losses its way (his words not mine) thats where the chattering comes from
  1. sat nav chattering
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:26
  2. turbocharger chattering/blowing/hissing? advice
    By total_vxl in forum Engine & Drivetrain
    Last Post: 27th February 2011, 19:55
