Thread: Cd30 into half canbus
    Oct 2010
    Aberdeenshire
    Engine : 1.9 CDTi 150
    Year : 57
    Default Cd30 into half canbus
    Evening people. Recieved my CD30 stereo and larger TID screen today (my veccy has smaller screen with clock buttons underneath). Been Reading through forums but I'm pretty lost on how I can fit this to my 02 half canbus! Sorry if all this has been asked before but what exactly do I need to connect this all up i.e connectors etc? I'm really not worried about having BC function, as long as I still have time, date and temp I'll be happy! The headunit and screen have been married together so will I get away without a Tech 2 session? Sorry again if you've heard it all before!
    Chris
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    To get radio working, you will need to get the ISO converted to fakra plug.
    Then you will probaly also need to rewire the 32pin plug to match the facelift..
    and then if you also have ECC (climatecontrol) you would also need a facelift one for that.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    As said above..
    Get an ISO2CAR or SOT lead to convert from ISO to quadlock connector for the head unit. (£16 from ebay or £30 from Halfords)
    Then you need to juggle some of your wires around in the screen...assuming you have the grey 32 pin screen connector.
    If you have the smaller 18 pin connector, then you will need to read Bigmac's How2 "TID to GID", which involves converting the 18 pin connections to 32 pin connections.
    You may require an aerial adapter plug as well from din or ISO to Fakra (Approx £2 from a car spares shop)
    Then if you have ECC, you will need to get the full CAN control panel.
    If you have steering controls, these too will need changing from buttons to scrollers.
    You will need your CIM programming for the change in steering wheel controls.
    Ideally, you would get everything Tech 2 programmed to suit.
    Depends if your CD30 and screen are paired. If not, then they will need to be Tech 2 programmed anyway...
    Oct 2010
    Aberdeenshire
    Year : 57
    Thanks for the reply guys appreciate the info. Sorry if its all been asked before, not very clued up when it comes to this sort of thing.
    Just wondering, do i really need to have steering wheel converted to scrollers straight away? Will the stereo still work properly without them as i'm really strapped for cash at the mo so having no steering wheels controls isn't a problem for just now.
    Cheers for the help again.
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    No, You don't need to fit them straight away.
    Yes the radio will work fine with no controls on the wheel... I ran a CD30 and a CD70 for years with no steering wheel controls at all.
    BUT - I would ensure that the CIM is not programmed yet for anything different..
    that is - if you have always had no controls, then just leave the CIM alone.
    if you have had buttons, then again leave the CIM alone.
    If you fit buttons or scrollers, and the CIM is programmed for "no controls", then you will sound the horn if you press any control button, or operate a scroller wheel.
    I have the screen wire positions on an excel spread sheet and also the wiring conversion for the ISO to quadlock conversion.
    (I have covered the options for Omega-B, Corsa-C and Cavalier-3, so half CAN Vectra-C / Signum is quite straight forward)
    Just pm me with your e-mail address, and I can send you the wiring details...
    Oct 2010
    Aberdeenshire
    Year : 57
    Robsey thanks alot for your reply. Will prob have a go at this once this weather clears, its a total nightmare here just now!!
    Chris
    Jun 2012
    Barnsley
    Hi there i know its a little past the date you last posted but you still wouldnt have them wiring diagrams would you. Would appriciate them as i'm going to attempt putting a cd30 into my half canbus vectra. Thanks
    Regular Member coldo's Avatar
    Scotland
    I would be keen to get this also as I could do a CD30 upgrade also on my half can car...
    I wonder... Are the CD30 all the same bar the front facia shape accross the vauxhall range? If so Could you not buy a CD30mp3 from an astra H and swap the front pannel with a cd30 (broken one) from a vectra to have it flush fit?
    Jun 2012
    Barnsley
    I could try, i'm good at following instructions but hopeless at working things out for myself. I could do with a step by step guide.
    Scotland
    you and me both lol
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. full or half CANBUS?
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2011, 22:29
  4. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
is a vectra c cd30 half canbus
