Thread: spaner light on?
    WALES ENGLAND
    Default spaner light on?
    can some one help spaner light came on other day,but car seems to be driving ok.the only problem is computer on dash board keeps telling me i got a brake light out but alls ok.How do i read problem codes and how do i get the codes up ?
    Regular Member Jezzy's Avatar
    S.E
    Read post number 4 in this thread:
    http://www.vectra-c.com/forum/showthread.php?t=121799
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by DECO View Post
    it says in my hand book "if car/spanner light comes on for a few minutes then goes off this is normal," I only have to change the brand of juice in my car and the spanner light has a mind of its own, I have done over 20,000 miles with this light on and off, I will only worry if it goes into limp mode.
    WALES ENGLAND
    niceone try that tomorrow,how do you read code into problem?
    WALES ENGLAND
    yer light goes out as soon as engine starts then drives great?
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    deco, mines been doing the same on and off for months now. and at points during the last 10 months actually didn't appear at start up.. In August alternator packed up so thought it may have been that. But two days after replacing alternator and having it reset, shes back, burning out my retinas in the dark. at first only on start up and then four two or three minutes of driving. So a friend of mine told me to check the glow plugs.. sounds a bit rough but all he asked me to do was remove the plug wires and connect a small wire to the + of the battery and touch each plug in turn. Each plug on contact should give off a wee spark, and hey presto.... plug 4 was dead, no spark..
    So I rang him up and he told me to take it out and test it properly. now after the first test i was kinda thinking i'm going to get burnt, so i used my jump leads and connected the negative to the shaft and the positive to the top of the plug and it hardly even warmed up. i could touch it virtually straight away.
    Replaced the faulty plug ( and got spare too ) and after couple of starts the famous yellow car spanner light aint even appeared..
    Even though the plugs are only used under certain temperatures, mines been intermitent all year, so I assume the controller module test the resistance on start up and brings up warning even if plugs ain't necessary
  1. revese swtich what size spaner
    By murf2484 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 00:26
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
