Results 1 to 10 of 23
Thread: V6 Diesel oddity?
    Oct 2010
    Lincoln
    Default V6 Diesel oddity?
    Hard to explain but it seems like once I am up to 'cruising' speed the engine appears not to run as smoothly as I would have expected. Seems to hunt around a bit. Acceleration is fine. Only just got the car so wanted to make sure it's something wrong not just me. It happens when I lift the pedal to maintain the speed after getting there.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mileage? How old is the fuel filter?
    I have something similar on mine (sometimes) and I'm suspecting a bad injector. Although mine judders more if I accelerate lightly up a hill in 6th 65mph-80mph.
    EVERYWHERE
    Does cruise control work OK?
    Oct 2010
    Lincoln
    Cruise control works but still feels the same. Done 72000 and has just been fully serviced.
    Oct 2010
    Lincoln
    Forgot to add that it seems to do it in any gear if the pedal is only just down a little.
    Oct 2010
    Lincoln
    Also hard acceleration is perfect
    Your profile shows a 2007 SRi 150
    Can you confirm the MY and engine
    If the car is over three years old, is it covered by a warranty?
    When was it last serviced?
    Oct 2010
    Lincoln
    Whoops sorry Profile updated. Just had full service.
    Oct 2010
    Lincoln
    It's covered by AA warranty, parts and labour.
    Quote Originally Posted by lencuff View Post
    With the engine on idle, it should be stable
    Watch the rev needle, does it move at any time?
    I suggest you try finding some long, straight, level roads of varying speed limits
    On quiet day, typically a Sunday morning, try some tests
    The first is at 30mph in as high a gear as possible, either 5th or 6th gear
    The revs should be very stable
    Look at the revs and see if they drop at any time
    The next is at 40mph, in 6th gear
    Same again, the revs should be stable
    Finally, find a dual carriageway road with NSL
    Start off as previous, at 30mph, then 40mph
    Accelerate up to 70mph in each
    You should then notice a vast acceleration from 2000rpm
    Finally, on a long run (10 miles or more) at constant speed
    Is there any "surge" from the engine at constant speed? (Normally this cancels the cruise control)
    In general driving, do you drive below 2000rpm or above 2000rpm?
    For example, at 30mph what gear do you drive in?
  1. Spanner oddity?
    By lencuff in forum Y & Z30DT Specific
    Last Post: 28th December 2012, 23:46
  2. A/C oddity
    By lencuff in forum Engine & Drivetrain
    Last Post: 5th July 2011, 08:18
  3. Towing oddity?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 19:11
  4. e bay item oddity - what's going on here?
    By mark_w in forum The 'Off Topic' room
    Last Post: 1st December 2008, 21:16
  5. immobilisor oddity
    By appy in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2007, 21:07
