Thread: lack of turbo
    Apr 2008
    leicester
    Default lack of turbo
    i drove to work this morning every thing was fine then all of a sudden the car went sluggish pulled up and stopped ,then put my foot down car took of with little power.It was just like driving my misses corsa no lights came on the dash i then got to work turned it off and on again drove down the road every thing was back to normal,has any one else had this happen ? went out at lunch time and drove home tonight and its fine
    WGAF#5
    as its the first time its doen it it wont have shown a fault on the dash - but it will have stored the fault code - when (and if) it does it again it will bring the engine light on.
    what were you doing as the fault occurred i.e. high gear at low revs and accelerating??
    how many miles are you on now Mick ? you might need to invest in the turbo solenoid bypass valves if its goinf to continue ....
    Apr 2008
    leicester
    im sure i was in third at about 3000 revs accelerating but not hard ,its just past 57000 miles
    WGAF#5
    hmmm, would be worth doing the pedal test and seeing what codes are stored unless you DO have a code reader ....sounds like the Turbo is loosing boost just need to determine where and the likely cause is either a small hole/loose pipe or the valves as above
    do you know how to do the pedal test to see if it has stored anything?
    Get in
    Press and hold both brake and accelerator pedals to the limit of their respective travels
    Turn ignition key to Position 2, ie dash lights on
    Release accelerator pedal
    Re-depress accelerator pedal to the floor
    Turn off ignition
    Turn on ignition to position 2
    The engine symbol on the dash will then begin to blink
    There will be a sequence of flashes, separated by small pauses between numbers and a longer pause between separate fault codes.
    The number of flashes needs to be counted and thus the 4 digit fault code can be determined.
    EG, if the flash count goes as such
    10 flashes
    small pause
    1 flash
    small pause
    1 flash
    small pause
    10 flashes
    Longer pause
    10 flashes
    small pause
    1 flash
    small pause
    10 flashes
    small pause
    10 flashes
    Then there are 2 fault codes recorded and they are
    0110 (ie 10,1,1,10 flash sequence)
    and
    0100 (ie 10,1,10,10 flash sequence)
    Apr 2008
    leicester
    no i dont know how to do the test it seems fine now but tommorrows another day
    WGAF#5
    look up one - i've posted the test method
    - if its happened once ...its going to happen again -
    stopping and restarting will clear the fault - just a pain having to find somewhere to pull over every five minutes or...even worse the limp mode kicks in whilst your halfway through an overtake
    Apr 2008
    leicester
    just given it a go got the engine light to come on but it wouldnt flash just stayed on ,turn it on and off again and the light dissappears
    WGAF#5
    not everyone seems to be abel to get the fault code test to work ...
    might be worth trying again as at present the fault only seems to be a "soft one" as the light is not illuminated ....but well worth trying again when and IF the fault reoccurs
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by micks edition 100 View Post
    you could do with someone reading the codes with op com, this will give you a better idea of the problem.
    Apr 2008
    leicester
    its not done it since so i have all things that cross, crossed been fine today not missed a beat
  1. Lack of power
    By McLovinH in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 22:17
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 20:18
  3. Badges (or lack of!!)
    By beakster in forum Bodywork & Interior
    Last Post: 8th November 2009, 00:08
  4. lights or lack of
    By Grimo72 in forum Styling
    Last Post: 5th December 2008, 22:26
  5. lack of c,s
    By neverlandandy in forum General Chat
    Last Post: 25th June 2008, 20:23
