Thread: Advice Needed
    Jul 2010
    Default Advice Needed
    Hi All, I joined the forum back in June when I was thinking of buying a vectra C 1.9 Cdti 150bhp well i actually bought a Golf GtTdi but my head is still toying with the idea of a vectra .. I have seen one on a 55 plate and looks rite enough but was after some advice regarding the injector wiring i was told to check if it is yellow and if it has been replaced with blue it is OK. could Anyone tell me where i would find the wiring ?
    And also the DMF and then EGR and Inlet manifold / swirl flaps (aint got a clue what DMF & EGR Stands for) again is there a specific way to check these
    Any othr advice would be apreciated
    Jul 2010
    DMF - DUAL MASS FLYWHEEL
    EGR - valve helps your car more efficiently and completely burn fuel by recirculating a portion of your exhaust and running it through the combustion process again. This results in a cooler, more complete burn of the fuel which decreases you car's noxious emissions by prohibiting the formation of some harmful gases
    stockport
    Arrow
    Quote Originally Posted by Doddy01 View Post
    What was omitted is the fact that this valve f***s your inlet manifold up eventually. FELIXX.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Hmm!, if youv'e got a decent golf then stick with it, the cdti's are great when there trouble free as any car is but if it aint broke why fix it!.
    Aug 2010
    Antrim
    Quote Originally Posted by the-wizard View Post
    The Golf is OK, but is small. Perhaps he wants a bit of room. The VW TDi is an engine with more than its fair share of mechanical issues.
    Liverpool
    aparently most post 2006 have most of the common faults ironed out (so i have heard, please dont quote me), so maybe bst looking for something a little newer if budget can stretch to it. By the time you buy a pre 2006, and replace all common faults as a precaution, you willhave spent just as much
    Jan 2010
    wirral
    Personally, I think the injector wiring is a minor issue. I had mine done last week, it cost me £30, including the labour.
    The main things to be aware of are the dual mass flywheel and the inlet manifold.
    I have had my inlet manifold replaced along with the swirl actuator....cost me £600.
    Also , the EGR would not be a major concern either, as they are not too expensive (£70-£100) and can be fitted by yourself, in no time at all, its only 4 bolts and an electrical plug in connector.
  1. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  2. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
  3. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  4. advice needed
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2008, 19:36
  5. advice needed
    By chrisgettings in forum General Chat
    Last Post: 29th November 2007, 19:57
