Results 1 to 10 of 23
Thread: Want to Replace Front Passenger Wing on Vectra C
    Nov 2010
    North West
    Default Want to Replace Front Passenger Wing on Vectra C
    Hi folks
    How easy is it to change a front passenger wing on a 2003 Vectra C? If anyone can point me in the right direction for instructions etc that would be great. I'm assuming I just need to remove light unit, trim covering bottom bolts, arch liner etc or do I need to remove anything else?
    Also, I'm hoping to just buy a 2nd hand one in the right colour (silver) to avoid paying for paintwork. Is there different shades of silver or is there just one for that model? If someone knows of a good place to go to for body parts or of anyone breaking a silver one let me know- thanks! :-)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There are several shades of silver. Look for the plate on the B pillar of the drivers door opening and look for the colour code. eg 2AU, to get a 'perfect' match with the donar car colour.
    Wing removal shouldn't be particularly difficult, it looks pretty straight forwards in TIS
    Nov 2010
    North West
    Ive read that 2002-05 all have the same shade of silver? Is that not true then?
    Anyone know a good place to get bodyparts?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    More than likely Star silver 3 which is 2au, Lightning Silver is more of a blue/silver colour if I remember right. As Ste says check the plate on the B pillar for the correct one. If it is the 2au code you'll be in luck, I think every other vec c i see on the road is star silver 3. Check your local breakers or ebay. Trouble with ebay is your unlikey to have any come back for a panel damaged in transit.
    Nov 2010
    North West
    Its star silver 3 that sounds promising :-)
    Ive been trying breakers and eBay but noone seems to have a silver one which I'm surprised at since as you say virtually 99% of the cars seem to be silver nowadays!
    If anyone comes across one let me know.
    Anyone got any advice on the actual job itself? (or links to instructions)
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    keithy just did a facelift on his prefacelift, im sure its a bumper off job with the only bolts that are a pain are the one behind the side skirt. I'll see if I find the thread for you.
    Nov 2010
    North West
    arghh :-( was hoping you only had to remove light - if you can find thread that would be great. Got a quote from vauxhall for a labour only to remove and replace wing and it was £141 + vat
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Had a look but cant see the thread, im sure he posted a pix of removing the front wing, but i'll stick my neck out and say yes its bumper off and the side skirt, if not fully removed then partially removed, then should just be about a dozen bolts to remove it.
    Nov 2010
    North West
    Any joy on finding some instructions?...anyone...?
    May 2007
    Norway
    It is in the HowTo-section, the pre-facelift to facelift conversion:
    http://www.vectra-c.com/forum/showthread.php?t=101927
    I replaced a front wing last summer on mine (Facelift version), and it is front bumper off, sideskirt loosend in the front, then the wing can be unmounted.
    A bit of fiddling/adjustments to get the new wing align up with the bonnet/side of the car, but with patience it is rather easy.
  1. How to: replace front shocks for Vectra C
    By SeeDeeXeye in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 00:25
  2. how can i replace a rear passenger door on vectra
    By krooney09 in forum Bodywork & Interior
    Last Post: 1st April 2009, 19:38
how to replace front wing on vectra c
replacement vectra front wing
replacing vectra front wing
