ive got a 07 vectra sri cdti xp.
how do i take out the fog lights to change the bulbs in them?? does the fog grill at the front come out to allow me to change the bulbs or how??
and wt u think of the osram nightbreakers H3, any gud??
cheers
cheers
Hi Tal .........you need to get on the ground and reach up underneath ..there should be a cap there that you just unscrew/pull off.....well it is on the preface lift ..I dont think you have to take the bumper off on the f/l ...someone might say different lol .
On my preface I had to undo two or three torx screws holding on that 'corner' of the tray under the engine and beneath the fog light.... this then folds down to reveal the underside of the fog lamp unit. At the base of this unit is a large round 'cap' that is a bayonet fit into the fog light unit. Give this cap a 1/4 turn to release it to expose the bulb.
F/L is just the same, just take the cap off from underneath, its easier if you get the car on ramps though because then you can see what your doing
yep, just get standard H3 35w hid for your fog lights....http://www.vvme.com/standard-h3-hid-...cPath=44_45_21 plug-and-play, it is better to choose 3k or 5k, not blind others eyes....
