Thread: Swirl Flap Stuck or Not Stuck ??
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Default Swirl Flap Stuck or Not Stuck ??
    Last saturday I had warning light came on, car was still running fine.. op-com told me it was P1112 - Swirl Flap Stuck .. I cleared the warning.. And it hasnt come back on since.. Anything to be worried about?? Can it stick and then free itself and be fine thereafter?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you checked the swirl pot rod to see if its still attached
    Jul 2010
    Buckinghamshire
    Umm, no I havnt, umm, thats a bit of a job for me to take on I think.. Throttle body removal I guess ? Is it easy enough? I think I remember seeing a how2 or some instructions somewhere on here but cant seem to find it.. Even though the error code hasnt come back you reakon it should really be pulled apart and checked out? What could happen If it isnt checked?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Remove the plastic vanity cover for the engine, look down just behind the fuel rail you will see if the bar is off or not.
    Gazza4
    Jul 2010
    Buckinghamshire
    oh, lol, that sounds simple enough (durr me)
    Thanks, I'll have a look in there tomorrow..
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    ive got 2.2 direct this happened with mine then after a month or two had to get swirl valve replaced big job on the petrol models so took it to a garage cost me a grand all in but that was replacing a few things lol hth.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Sorry m8 I thought you had a 1.9.
    Gazza4
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by nibblitz View Post
    Is this for a CDTI 150??
    If so I have pics showing you what is needed to check.. Let us know.
    You can also test the swirl actuator movement via Op-Com
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by simplesi View Post
    The 2.2 has swirl valves?
    Jul 2010
    Buckinghamshire
    Quote Originally Posted by AntSSSS View Post
    No, my motor is a 2.2 direct, pics to show me what to check would be useful if anybody has any ...
  1. error code p112-61 swirl flap stuck
    By dahmich in forum Engine & Drivetrain
    Last Post: 7th December 2012, 13:36
  2. swirl valve stuck ??
    By coooky in forum Engine & Drivetrain
    Last Post: 27th June 2011, 19:46
  3. Ok.. I'm stuck !!!
    By spoons in forum Games Room
    Last Post: 23rd December 2010, 19:38
  4. Help pls - Petrol Flap stuck!
    By moorlander in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2010, 10:55
  5. swirl stuck
    By in7ox in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 10:50
signum swirl flaps
