Results 1 to 10 of 15
Thread: RHD to LHD headlamp adjustment
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default RHD to LHD headlamp adjustment
    Should the adjustment lever be up or down for RHD UK driving, cant seem to find an answer anywhere lol
    Bristol
    Ummmmmm can't remember.
    I THINK its up on one and down on t'other!!
    Best way is to get someone to stand in the headlamp aim and flick the lever to see if the shutter comes down.
    Regular Member Jezzy's Avatar
    S.E
    For driving abroad:
    N/S = lever goes up
    O/S = lever goes down
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    if youre talking about the levers which give the 'kick up' on the nearside part of each headlight beam, i would say that both 'kick ups' should be up when driving in the UK & down when driving in europe.
    remember to return them to the UK setting before you take it for its MOT, or else it will fail! saw this recently on a MOT failure report at the workshop where i work!
    S.E
    Quote Originally Posted by kentish_bloke View Post
    No mate, one up/one down is as stated in the user manual.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    For driving abroad:
    N/S = lever goes up
    Right so mine should be oposite to that, cheers
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    well, both my 'kick ups' are set to up on my prefacelift, which i am assuming the OP has.
    the MOT failure report i saw recently clearly stated that one of the 'kick ups' on the failed car was missing, hence the failure. surely the MOT tester couldnt be wrong, unless theyre working for Kwik-Fit LOL
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Maybe aiming against a wall is best then
    Bristol
    I think you've slightly misunderstood the question of the OP.
    We realise that both lights must have the "kick-up" but it is the lever position which controls the kick-up which the OP is asking about.
    One side the lever must be in the up position, and the other must be in the down position. In this state both lights will have the kick-up
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    thats how i did mine, watching the beam pattern while flicking the levers. i have absolutely no idea which is up or down, so assumed mine were both up due to the presence of the 'kick up'.
  1. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  2. Headlamp adjustment message after lowering
    By Harro in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2010, 18:28
  3. Headlamp beam adjustment for europe
    By goonturbo in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 20:49
  4. Automatic headlamp range adjustment fault!
    By djhallam in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2008, 09:10
  5. AFL Headlamp adjustment?
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 01:36
insignia setting to the rhd
vexyra c headlamp lhd
