Thread: Vectra C turbo problems
    kent
    Default Vectra C turbo problems
    Hi all,
    i have had problems on and off with my vecra for nearly a year now but since the cold weather started it has been almost constant.
    I can be driving it in any gear and at any speed and the turbo will just cut out and it will become really slow.
    Before last week everytime it was doing this, a car with a spanner would appear. I could turn it off then back on and it would be ok again.
    Last week i had the same problem but the engine management light came on, after turning it off and on 5 or 6 times the light was still there and has been ever since even though the power comes back occasionally for a few minutes.
    I had them run a diagnostics a few months ago when the problem was less frequent and it came up with these fault codes:
    P1105 barometric pressue
    P0105 vacuum solenoid circuit high
    P1590 high solenoid value
    I was told by the garage (not vauxhall) that they thought it was the solenoid but after looking on the internet i read about alot of people that had this changed but still had the same problem.
    Does anyone have the same problem or have any experience with this? What are the most common things that may cause this?
    Many thanks in advance for your replys
    Michelle
    xxxx
    Firstly I would check all the hoses for splits and clean the turbo pressure sensor as its a 2.2 dti
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Lol how do you know that engine it is....
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Regular Member Dazzy2006's Avatar
    Notts
    Also seeing as its a 2.2dti try cleaning the boost sensor and the egr valve as it doesnt cost a penny and seems to solve alot of problems
    I have a feeling big sig calls it a turbo pressure sensor
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Caveman_nige View Post
    Profile
    Notts
    2004 2.2dti elite
    kent
    just checked all of the rubber hoses i can get to and none seem to have any splits in them.
    Where would i find the other things and how do i clean them?
    I dont mind getting dirty but dont want to mess it up anymore than it is!
    Michelle
    xxxx
    Notts
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Have a look in the 'how 2' section on this forum, there should be details on removing & cleaning the EGR & boost sensor, these are fairly easy jobs. as above! beat me to it.
  1. Vectra 2.0 Sri Turbo Front Fog Problems
    By oodjsparkiedeeoo in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 21:51
  2. turbo problems
    By bobthebarber in forum Engine & Drivetrain
    Last Post: 22nd January 2012, 20:35
  3. Turbo problems?
    By warren77 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:04
  4. turbo problems
    By chrisgo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 15:32
  5. Turbo problems 2.0 Dti
    By brotherkennyh in forum Engine & Drivetrain
    Last Post: 27th August 2010, 12:19
