Thread: v6 diesel auto
    Sep 2010
    walsall
    Default v6 diesel auto
    finally got my fault codes read.
    the original problem was my auto box was going into limp mode when the car got warmed up sometimes. it started juddering & judering into gear.
    fault codes.
    p0735
    p0705
    p1700
    p1704
    can anyone point me in the right direction as what to do next.
    do i take it to my local auto expert?.
    cheers mark.
    Find the passcard
    Disconnect the battery for at least one hour
    Recheck for error codes
    Start engine
    Sep 2010
    walsall
    sorry to ask but what is the passcard?.
    Quote Originally Posted by porkaboy View Post
    Contains all the lock codes and radio codes; you will require this to reset the stereo, otherwise it will be locked on reconnecting the battery
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    fault codes.
    p0735
    p0705
    p1700
    p1704
    cheers mark.
    P0735 Gear 5 Incorrect Ratio
    P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
    P1700 Transmission Indeterminate Failure (Failed to Neutral)
    P1704 Digital TRS Failed to Transition States in KOEO / KOER
    Sep 2010
    walsall
    the chap who gave me the codes told me what they all where but that still does'nt tell me nothing.
    where do i go from here, is it a gearbox expert or do i try the battery off for an hour job & hope it does something?.
    i do have the passcard.
    is it just the radio which will need reseting?.
    cheers mark.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, just the radio.
    It may be that the gear selector is giving odd signals to the gearbox ECU (hence P0705), maybe a loose connector or dirty sensor?
    I would also check the fluid level - can cause a lot of 'false' issues.
    EVERYWHERE
    It may only be the p0705 code that is triggering the rest.
  1. What's auto box like on 3.0 diesel?
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2011, 13:58
  2. v6 Diesel Auto box problem
    By NPS in forum Engine & Drivetrain
    Last Post: 5th April 2010, 09:53
  3. 1.9 150 Diesel - auto or not?
    By runboy in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2007, 18:11
