Results 1 to 3 of 3
Thread: HID's problem
    Regular Member fingers66's Avatar
    Carpe Diem
    Default HID's problem
    I have had my hids fitted for 7 months now, everything's been fine, untill now, my driver's side goes out after a couple of minutes, I need to switch of ignition to get it back on,....... At the weekend I put in 1 of the extra cancelers I got from Hids direct, still the same problem, I have the 35w 6K from hids direct,.......any idea's guys/gals
    Bristol
    First thing I'd do is swap over the ballast's to rule them out.
    If the passenger side now goes out then it's the ballast and you need to replace it.
    If it's still the driver's side then it's the bulb.
    If neither go out you had a loose connection and it was sorted when you swapped the ballasts!!
    Carpe Diem
    Cheers Gayno, I've just been out to take bumper off,lights out, changed balasts over.....and its still the same, so I take it the bulb will be shot, bummer.
  1. Hid's
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 02:39
  2. HID's fitting problem
    By Smudger34 in forum Styling
    Last Post: 11th June 2012, 12:57
  3. Hid's. 35w or 50w?
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2011, 19:03
  4. More on HID's
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2009, 17:58
  5. hid's
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 19:16
