Thread: Wheel wobble
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Default Wheel wobble
    My son has got a wheel wobble more so when braking and at high speeds ...its not the wheels that need balanced as we have just had new tyres fitted thought it might be the disc's but they are OK too tracking has also been checked ..track rod ends seem OK anyone any idea ?
    Sep 2010
    Hartlepool
    Could it possibly be anything to do with the speed rating of the tyres?
    My father-in-law has cheap tyres with lower speed rating on his vectra and he gets quite a bit of wobble even at 70. I can do 70 with my Bridgestone Turanza's (Higher speed rating) and I get nothing and we both have the same engine size except his car is 18 months newer than mine (Mine is 54 reg pre-facelift and his is 06 reg facelift).
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    I would re check the tyres might have a lump or one of the weights might have fallen off but does sound like the discs are shot if it happens when braking
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by markj23 View Post
    this is what we thought with the tyres but still have it with the new ones ...the discs were mine that i gave him a while back ...they look perfect and were ok when i had them its not as if they are all scored they are pefectly smooth
    Aug 2010
    Luton
    ho i did not realise it was happening prior to new tyres as well sorry does it feel like pulsing when you hit the brakes? if so its warped discs can happen and not look damaged
    Jan 2010
    glasgow
    prob the discs bud, have you changed the wheels around front to rear to see if its poss a slight buckle ,to be honest it could be a few things has he went over a large pot hole could it be he has maybe did damage to 1 of the drive shafts ?or maybe the bearings in 1 of the hub carriers.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yeah deffo sounds like the brakes mate, as said they may look ok but they could still be warped. If you brake harder does it vibrate harder?
    WGAF#5
    i agree its probably the discs or pads if they were fitted to another car first they may not be seated fully on the new car or they have had a small anomoly thats been amplified now they have been transferred to the new car
    Edinburgh/outskirts
    Mileage : 38000
    I would have said it was discs also but having been in the car and seen the wobble when driving at different speeds IE 45-70 im am lost
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The vibration defiantly coming through the steering wheel Signumboy? it may be crap behind the disc on the hub face. You'd need to use a run out gauge to on the discs to help determine if the discs are warped or not, even a slight warping can cause a huge wobble at speed.
  1. Wheel Wobble - What next?
    By logi6260 in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 16:13
  2. steering wheel wobble
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 22:44
  3. Wheel Wobble
    By rsocon in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 14:15
  4. Wheel wobble at 40 to 50 mph
    By iwoo in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2009, 15:56
  5. Wheel wobble
    By raymie.d in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2007, 16:09
