Results 1 to 10 of 17
Thread: Hids
    OXFORD
    Default Hids
    Vectra C Facelift 58 plate. After trying nightbreaker plus bulbs (better than normal) i have brought a Hids kit from Hids direct. Can someone tell me on the original plug that plugs onto the bulb,which colour wire is the live.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yellow
    Browns are earth
    OXFORD
    Yellow
    Browns are earth
    OXFORD
    Hi
    When fitting the hids kit, the live and neutral spade connectors plug into the original light plug. One side has 2 black wires the other side one black wire. Can anybody tell me which is one is live.
    11 Post(s)
    The one with 2 wires is the earth, IIRC.
    If you get it round the wrong way it doesn't matter anyway. All that'll happen is the lights won't come on. Simply unplug and swap the connections around.
    Sodding Typical on Sea
    I agree with that but the only way to be sure is to try it if it doesn't work, reverse it!
    I did and it worked then.
    stockport
    Arrow
    Quote Originally Posted by Derek Mc View Post
    (Sorry to hijack the thread).Derek,on one of the other HID threads someone mentioned using a spare set of ballast on the main beam.This has got me thinking,because the dodgy ones that I got off eBay are still in the car,(i'm waiting to put the HIDs Direct ones in this weekend),well,if I was to wire the Main beam up to them,with a set of bulbs of course,would I need a set of cancelers in place do you think?. FELIXX.
    OXFORD
    cheers
    stockport
    Arrow
    Quote Originally Posted by DJJ View Post
    cheers
    I only jumped in because I thought you had the answer you needed.Please accept my sincere apologies,no offence was intended.FELIXX,
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Hi
    Sorry mate didn't realise the Facelift doesn't have any colours
    Quote Originally Posted by felixx View Post
    Don't think he was having a dig at you buddy
    You'll need to use cancellors on any other set as you'll still get bulb failure warning on main beam
  1. Hids
    By barneytravolta in forum Styling
    Last Post: 6th August 2012, 18:23
  2. HIDS again.....
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2012, 09:18
  3. hids (HELP!!!!!!!)
    By cookiejar31 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 20:20
  4. hids
    By cookiejar31 in forum Styling
    Last Post: 28th November 2009, 02:50
