Thread: cambelt change- Help needed
    Oct 2010
    N. Ireland
    Default cambelt change- Help needed
    Hi guys,
    Im in the middle of doing cambelt change on 07 1.9 cdti 150.
    Im as far as engine mounting completely off, drivebelt off.
    Removed the 4 torx bolts holding the drivebelt pulley to crankshaft pulley.
    It doesnt seem to want to come off?
    The bolt in the centre doesnt need to come out does it?
    Any advice appreciated.
    I have looked at pictures in how 2 and the centre bolt is still intact.
    http://www.vectra-c.com/forum/showth...t=crank+pulley
    Hi melvin, have a look at the above.
    Regular Member DaveW555's Avatar
    Cannock
    the bolts in the crank pulley aren't torx bolts they're ribe bolts its a different socket for them, just be careful using torx sockets in them in case you round them off.
    Oct 2010
    N. Ireland
    Thanks lads, I got it off, it was just siezed to the crank pulley. A few taps with the hammer done it.
    Fitted the belt, now just want to ensure correct tension.
    The slot on the tensioner is sitting on the guide pin on the engine,
    Where abouts does the pin be when correct tension.
    Would it be midway along it.Hope you can understand this.
    Cannock
    it should point to the hole in the back plate of the tensioner
  1. Cambelt Change
    By xoborp in forum Engine & Drivetrain
    Last Post: 7th February 2013, 21:12
  2. Cambelt change 1.8 VVT
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2011, 16:50
  3. cambelt change
    By tonelyone in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 14:42
  4. Cambelt change
    By johncharles in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2009, 15:15
  5. cambelt change
    By chappie in forum Introduce yourself.
    Last Post: 28th April 2009, 07:48
