Results 1 to 10 of 11
Thread: Rear Camber Adjustment
    spoons
    Guest
    Default Rear Camber Adjustment
    What have people done regarding their rear camber adjustment with coilovers fitted?
    Anything or nothing?
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    I have heard that there is not alot of camber adjustment on the back but i do believe that Eibach do camber adjustment bolts that are longer than the standard ones.
    Only other problem i found was that not alot of people are willing to adjust the rear camber.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    LMF do camber ajustmentbolts..
    spoons
    Guest
    Quote Originally Posted by kenp View Post
    They do.. I spoke with them this morning... but only for the front
    Nothing for the rear
    Engine : 2.2 Direct
    Ahhh I thought it was the rear they sold.
    Jan 2010
    Liverpool
    When I changed the rear bushes and track control arms on mine I noticed there were offset head bolts holding the lower arms on (iirc). I guess you may be able to get some adjustment in camber from these.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    i thought the rears already had bolts in... only fronts you needed to buy?
    Regular Member hagga's Avatar
    kingswinford
    there isn't enough adjustment on the rear to bring camber back into spec but you may be able to fit camber shims (I need to looky next time rear wheels are off)
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    when i had my vectra, i had the camber set to the most upright they could get it which was about -2.6 degrees, i had the car sittin as low as it would though.
    Theres a company in australia that does camber adjusters for the rear, K-Mac (not sure if they still do them or not) I bought a set for mine, but decided not to fit as i wanted the camber and tyre wear wasnt as bad as i thought.
    the K-mac kit replaced the outer bush of the upper control arm.
    23 Post(s)
    Mileage : 110k
    Seen the bush kit, but its £200+
  1. Camber adjustment?
    By Neil07D in forum Handling & Braking
    Last Post: 22nd January 2012, 11:20
  2. Front camber adjustment?
    By Tayla in forum Handling & Braking
    Last Post: 11th November 2010, 17:56
  3. Location of Adjustment Points For Rear Camber
    By marcdale in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2008, 09:29
  4. Estate Rear Camber Adjustment
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2008, 08:26
  5. camber adjustment
    By hagga in forum Handling & Braking
    Last Post: 12th November 2007, 15:45
vectra c rear camber
vectra c rear camber adjustment
vectra c camber adjustment
vectra c rear camber bolts
vectra c camber problems
adjusting vectra c rear camber
rear camber settings vauxhall vectra
Vectra adjust camber rear wheel
how to fix front camber alignment vectra c
vectra c camber front
how do i adjust vectra c rear suspension
vectra c camber bolts fitment
how to set rear camber on vectra
vectra c estate camber rear
vauxhall vectra c rear camber kit
vectra c camber kit
vectra camber bolt
vectra c rear factory camber
vectra c rear camber adjustment replacement bolts
vectra c camber settings
https:www.vectra-c.comforumshowthread.php121631-Rear-Camber-Adjustment
camber vectra c
rear camber on vectra c
vectra c front camber adjustment
