Thread: Funny Judder
    Regular Member tammyman09's Avatar
    tamworth
    Question Funny Judder
    Hello all.
    I have a funny problem with my Veccy. its a 1.8 petrol. Now, just recently with the damp mornings or rainy days, when I put the car into reverse, or pull away in 1st or change to 2nd gears, I get a funny judder thats quite violent when it does it. almost like the car is stalling.
    if i rev it higher when i pull off or change to 2nd, it dosent do it. but this will inevitably burn the clutch out and its only been replaced a year ago.
    does anyone have any ideas of what could be causing this?
    as i say, its only when its been heavily raining or a damp morning. it dosent do it when its been a dry day/night.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Might be a rust spot on your clutch pressure plate. I had a similar issue on a Cav after I drove it through surprisingly deep water. Luckily it was a company car!
    Phil
    Regular Member DaveW555's Avatar
    Cannock
    Check the front and back engine/gearbox mounts they're a poo design and would give the symptoms you describe but its not weather specific.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i have a similar problem when slipping the clutch when pulling away in 1st, have had it since i got the car when it was just over a year old.
    it never happens during the summer, & usually disappears once the engine & gearbox have warmed up.
    as far as i know it is a common thing with 1.8 clutches. just increase the revs a bit when slipping the clutch to pull away, but dont race the engine as thatll reduce the life of the clutch. youll soon get used to the required revs & amount of slip during the colder months.
  1. Judder and eml
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 07:41
  2. Judder at 50 to 60
    By Faz2726 in forum Troubleshooting
    Last Post: 17th January 2012, 00:00
  3. judder
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 28th December 2011, 14:41
  4. judder
    By twaiter in forum Engine & Drivetrain
    Last Post: 14th July 2009, 21:26
  5. Funny thing happened tonight on the way home !! Not Ha Ha Funny !!
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2008, 02:26
