Results 1 to 10 of 11
Thread: Torx Bolt Size - Rear Suspension Dampers
    spoons
    Guest
    Default Torx Bolt Size - Rear Suspension Dampers
    Hi all,
    I need to undo the rear dampers as I cant adjust the rebound without removing the shock from its bolted position
    Anyways... anyone know the size of the torx bolts that hold the rear dampers in place as I need to go buy one
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    T18 on the bottom and T20 on the top if I remember rightly
    spoons
    Guest
    Quote Originally Posted by Caveman_nige View Post
    How accurate is your memory as I'll go out and buy these later today
    Jun 2009
    South Coast
    pretty accurate.. lol
    you will do it with those two mate..
    Jun 2009
    South Coast
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    The above is right, E20 for the shock top and bottom and E18 for the lower arm.
    I bought the Draper Expert 14 piece socket set that goes from E4 to E24 for £18.
    Jun 2009
    South Coast
    lol yeah thats right they call them e sockets and not T..
    E for female and T for male, obviously
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Its all confusing coz they still call them torx sockets, had to buy them to do my suspension at the weekend but as most of the other bolts are torxs it will be a great addition in my tool box.
    spoons
    Guest
    Great thanks
    So I just need an E20 for the damper top and bottom bolt then ?
    I just need to move the damper thats all.
    Also, anyone know the torque settings for these bolts?
    Jun 2009
    South Coast
    no mate, E20 is for the top bolt, and E18 is for the bottom bolt, you will need both
  1. Rear top seatbelt runner Torx size?
    By BigWilko in forum Bodywork & Interior
    Last Post: 21st May 2012, 19:25
  2. Steering Wheel bolt torx size
    By Vectra Forever in forum Bodywork & Interior
    Last Post: 18th July 2011, 22:06
  3. Boost valve torx bolt??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 17:34
  4. TORX bolt size ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 15:19
  5. what size torx bit for rear seatbelt?
    By spartan80 in forum Bodywork & Interior
    Last Post: 19th January 2008, 22:27
saab 93 what size torx rear shock absorber
vectra z18xer suspension bolts
size bolt vectra c control arm
opel vectra 2006 1800cc rear shock absorber
what size is the rear shocker nut on a corsa c
vauxhall combo shock absorber bolt
vectra rear subframe torx
how to change rear shock absorbers on vauxhall vectra c
vauxhall zafira rear shock absorbers e18 torx size
corsa c rear shock bolt size
what size torx bit it on a vauxhall vectra c suspension
vectra c rear control arm torx
2005 vectra spring bolt sizes
vectra c trailing arm bolt size
bolts for rear shocker on 2006 vecttra
vectra c torx bolts
rear shocker bolts for.vectra 2006 1800cc
rear dampets star bolt size on vectra c
