Results 1 to 10 of 17
Thread: Hunting problem returned
    Regular Member manimal's Avatar
    Grimsby uk
    Talking Hunting problem returned
    I fitted an ECU because the other one was faulty as some might already know & it cured my hunting fault.But after a day the hunting returned...bummer !
    It only hunts intermittently on idle......it'll hunt for a couple of mins the be ok for a couple of mins & so on.The only thing that seems to calm it down for a bit is if i switch my rear demister on....
    Anyone throw any light on this & maybe found a solution....it's damn annoying !
    Maybe i should buy a pushbike lol.
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I know Bobssignum had this problem and I think from memory it turned out to be the throttle body that was the fault, although he can probably confirm that one way or the other.
    Sep 2010
    Hartlepool
    Just wondering if the idle revs are set right as turning on the rear deimster (among other things) increases the power requirement and the revs increase slightly to accomodate for it.
    It makes me wonder if the idle revs should be set a little higher or if whatever controls the revs is not consistent.
    As Ian says, it could be an intermittent fault with the throttle body causing the revs to drop among probable numerous other things.
    Do you have any problem with the car when driving it?
    Grimsby uk
    The car seems to run ok when driving until i wait at a junction then it hunts until i increase the revs a little.
    north east
    WHhich engine do you have?
    Grimsby uk
    The engine is a 1.8 petrol Z18XE 2002/3
    I know it's not the EGR valve because it was built without one fitted.
    Regional Organiser - East Region whiskyno7's Avatar
    norwich
    14 Post(s)
    Vehicle : vauxhall signum
    Trim : 2.0t
    Engine : chipped and remapped
    Year : 03
    Mileage : 100k+
    Quote Originally Posted by manimal View Post
    mine did that 1.8 sri. had a new cpu. mass air censer. and egr valve put in and it stopped one was the cure i dont know witch one. mine hi Revd. ans miss fired before it got sorted with a new cpu.
    it say's it all
    Sep 2009
    Audley STAFFS
    my 1.8 used to do this when I first had it, after a 500 mile Mway trip it was hunting bad, all I did was use injector cleaner, I use redex at most fill ups, have had no further problems in 15,000 miles.
    Grimsby uk
    i've tried injector cleaner,but not redex,maybe try that,should'nt have to use additives all the time i would'nt have thought.There must be a permenant cure, surely
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sounds like the throttle body need cleaning to me. Probably the ECU has nothing to do with it.
  1. The problem has returned!!!!!!
    By collyb in forum Engine & Drivetrain
    Last Post: 25th April 2011, 23:36
  2. HID returned !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 19:25
  3. Hello to all - I have returned!
    By chrisschild in forum Introduce yourself.
    Last Post: 9th July 2010, 17:22
  4. Hi - I've returned!
    By Terry Tibbs in forum Introduce yourself.
    Last Post: 30th January 2009, 11:02
  5. i have returned!
    By pogo in forum General Chat
    Last Post: 2nd December 2006, 10:50
vectra 2.0 turbo hunting
