Results 1 to 10 of 25
Thread: Spanner light on 2.0L Dti
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default Spanner light on 2.0L Dti
    Hello
    I had a weird thing happen on Saturday, I was towing the caravan down the M60 Saturday morning doing 56mph with Cruise control on about 10 miles into journey, when the spanner light came on cut out CC and felt the engine power down, so pulled onto to hard shoulder only to find everything was fine. Its the first time it has happened, I just put it down to using CC while towing, but it did not happens on the way back!!
    Has this happened to anyone else, or is it one of them little niggles like I had in my Fix It Again Tomorrow.
    Regards
    Dave
    Regular Member Innes's Avatar
    Plymouth
    My car used to go into Limp-Home-Mode when I strained the engine e.g. 5th gear low revs up a hill on the motorway. It turned out the vacuum pipes had splits in them so I would check them first. They can be replaced for about £6 off ebay (you'll need about 3 meters). I use the below pic to show DTi owners 'The Usual Suspects' when it comes to the spanner light.
    PS - Please note that your vacuum pipes may be on the left rather than the right like mine. Vauxhall moved them as the hot gearbox below was causing the vacuum solenoids to fail.
    Oct 2010
    Walkden, Manchester
    Excellent, will have a look at mine tonight and see if they need replacing. If they do I best get the old tape measure out to get the dimensions of the pipes I need to order.
    Bristol
    3 metres of 2mm internal diameter. Can be found readily on eBay for about 6 quid!
    Maybe it's because you were towing a caravan and it couldn't face the embarassment any longer?!
    Plymouth
    They are 2mm Silicone vacuum hose and you'll need about 3 meters. Here is a link to it on ebay:
    http://cgi.ebay.co.uk/2MM-ID-VACUUM-...item3f03990601
    and here is a thread I started awhile back about it. You may find further information there.
    http://www.vectra-c.com/forum/showthread.php?t=115759
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I don't think this is Boost sensor,egr, vacuum or boost pipe related. Try checking all of these but I think your turbo actuator rod is needing turned slightly. I had this same problem on my 2003 2.2DTI
    Problem is that at around 60 mph in 5th gear the turbo is sitting just about starting to boost
    If you try towing at 60mph in 4th you'll notice you get no spanner light
    Plymouth
    How do you adjust the turbo actuator rod? Got any pics?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not right at this moment as i'm away to go to the dentist but I will get pics
    Oct 2010
    Walkden, Manchester
    Me thinks i might of just wasted a tenner on hose, as mine are on the left and i do not know what pipes are vaccum hoses, oooops
    Sep 2010
    north east uk
    Quote Originally Posted by Jonsey View Post
    No you havent wasted your money mate. Your engine is the 2 litre DTI (Y20 DTH) right?
    If so, then the pipe you bought will still do the job....its just that the pipe layout is different. Will post a pic up when i get a spare 5 mins.
    I just ordered some of this pipe today for my 2 litre DTI 04 reg.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
2.0 dti y20
