Thread: Auto dimming rear view mirror
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Default Auto dimming rear view mirror
    I have put the auto dimming rear view mirror in today using a wiring loom from a car in the breakers yard, do I need to get it tech 2'd before it will work?
    Full Member
    South West
    It should just work... mine did. Do you have the little orange light on the bottom of the mirror? That will be a good indication, or just shine a bright light in to the sensor when its dark
    Rgds
    Aidi
    Sep 2010
    6 Post(s)
    Trim : SRI
    Default Mirror
    There is a light on from the bottom of it, and it does dim if you put the interior light on, found that out after posting this thread, but if I put it in reverse or open the door it still stays dimmed, I thought it should cancel it?
    Lee
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    How did you wire it in?
    and for those functions you will need tech2 if you used oem wiring.
    Sep 2010
    6 Post(s)
    Trim : SRI
    I used the GM loom from a car in the breakers yard, it is a genuine one. So I need to find some-one in the midlands area who will tech 2 it for a reasonable amount.
    Thanks guys
    Engine : 2.2 Direct
    yes only need to set it present in the REC job done.. takes less than 2 minutes...
  1. Auto Dimming Rear View Mirror
    By GSiSnash in forum Bodywork & Interior
    Last Post: 23rd August 2012, 02:11
  2. Auto Dimming Rear View Mirror and Loom
    By BigP in forum Parts for sale
    Last Post: 8th June 2009, 21:47
  3. Auto dimming rear view mirror
    By Steven T Davies-Moss in forum Parts for sale
    Last Post: 24th March 2009, 15:43
vauxhall vectra c autodimming rear view mirror wires site:www.vectra-c.com
