Results 1 to 10 of 29
Thread: Glow plug replacement
    Engine : 1.9 CDTi
    Default Glow plug replacement
    Should you replace glow plugs in sets or just the one (Or two) that have failed?
    Also what glow plugs do people recommend and what roughly should I expect to pay?
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    As a matter of course I would change all 4 TBH lee!!!
    I am hopefully going to get mine done in a couple of weeks (nightmare to start on these cold mornings and huge clouds of black smoke) but being the 120bhp engine I'm a little nervous and not sure where to get it done.
    I have the glowplugs already, bought a set of 4 on ebay (NHK) for around £35
    Going to try and see if Vauxhall will change them for me and get a service done at the same time (feeling the burn in the pocket already)
    Where abouts are you based in Hants and have you been given any quotes for changing them???? or are you planning on doing them yourself????
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Engine : 1.9 CDTi
    I am a mechanic (In the middle of doing my level 3 and been playing with cars for 20 years) so going to do them myself.
    I am just outside Portsmouth.
    Year : 55
    Mileage : 92,000
    Ahh small world, I live just outside petersfield
    Did think about doing them myself but after hearing all the horror stories of them snapping etc I am thinking better of it and perhaps leave it to the professionals (used loosely)
    I've just had a trawl through NGK's website and according to them there are two types of glowplug for the VECTRA (pictured below)
    Attachment 36244
    But seeing as yours is a signum it should be the YE07 varient. Hopefully some of the other guys on here can confirm
    Anyway best of luck with it and remember
    Damo
    Already replaced:-
    Alternator,
    Bristol
    Vehicle : CDTI 150
    Quote Originally Posted by lee gsi View Post
    Best to replace all 4 as they've all clocked up the same operation. Others may fail soon.
    Best to give a squirt of Plusgas or similar on a cold engine the day before, if possible leave overnight.
    Change plugs with the engine warm.
    You need a deep socket, 8 or 9mm.
    Make sure you dont apply any sideways movement when rotating the socket.
    The torque setting for glow plugs is 10nm.
    I use Bosch, which it what Vx fit.
    Good luck
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as above they don't come any better than bosch
    Year : 55
    Mileage : 92,000
    Well with that in mind, I think I may have made an error with the glow-plugs I've bought (got the NGK Y-534J)
    What's confusing me, is that according to NGK there are two sizes of plug for the 8V (120), one being 10mm dia and the other being 9mm dia
    Am I right in saying that the BOSCH plugs I would need to order is the GLP007???
    Not sure if that's for 8V or 16V though??? Wondering weather I should just buy some more (found some GLP007 for £9.16each)
    Can't find any definitive answers covering the different sizes of plug for the 8v CDTi or is this where I need to remove the plugs first in order to ascertain what size they are
    Any idea how much Vauxhall would charge to get these changed over (roughly)
    Sorry for the thread hijack lee but can anyone offer any advice???
    Many thanks
    Damo
    Already replaced:-
    Alternator,
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I can confirm that the cdti 150 are 9mm, don't worry about the make! in general if there a 'brand' name of any make they will be fine, Most people will replace ALL!, but as an old hand i only replace the one/ones that are gone, A typical example is!, A chap sent his x wife to me to look at her diesel peugeot 405 hdi (poor starting from cold), I tested the glow plugs, found 1 gone (3 were new, but 1 was awkward to get at & was not previously replaced), I quoted £4.64 for 1 new plug, As it was a mates x- wife i told him i would do it free of charge, as it was Sunday aft she was to come back, 5 weeks later i bumped into him in the pub only for him to say 'Ive sorted the job!' he sent her to kwik fit & had all 4 changed for £60!, This is like changing all four tyres because one is worn!, you cant change some people! & I'm an x haulage contractor & vosa approved repairer!.
    Year : 55
    Mileage : 92,000
    It's such a shame you weren't closer wiz I may have kindly called upon your expertise and guidance
    Not sure where the plugs are on the 405 but as the ones on mine are buried right down the back of my engine, think they (Kwik Fit) may double that figure
    May well make a few phone calls in the next couple of days and try getting some quotes.
    Hoping I've bought the right plugs now as I've gone and bought the 10mm ones (according to NGK)
    Many thanks for your advice wiz, hopefully I'll be able to get mine sorted for around £60
    Damo
    Already replaced:-
    Alternator,
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    They are not that bad really!, Try the open end of a spanner on 1 of the plugs!, if you have a 9 + a 10 you will know for sure!, if you only have a 10 then it will be a sloppy fit!, I would honestly only change the 1 thats faulty!, is it bad starting?, is this the main reason for you changing the plugs?.
  1. 1.9cdti 120 glow plug replacement.
    By john1 in forum Engine & Drivetrain
    Last Post: 14th November 2011, 23:27
  2. glow plug problem i think
    By leech in forum Engine & Drivetrain
    Last Post: 24th May 2010, 18:38
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. Glow plug replacement
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2008, 10:23
do kwik fit do glow plugs
torque settings for glow plugs on a vauxhall vectra c
