Thread: wheel stuck
    Regular Member Darren68's Avatar
    Jun 2009
    Vehicle : vectra
    Trim : exclusiv
    Engine : 1.8
    Default wheel stuck
    went to take front wheel off took all bolts off only to find wheel stuck to hub any advise on what to do next and what to use to stop this happening again.
    Mileage : 000
    Put the wheel bolts back in. But not all the way in. Then with a hide mallet hit the tyre. Whilst rotating the wheel. I don,t suggest hitting the rim though, By putting the bolts back in "loose" the wheel will not fly off if it comes loose. Then if you do manage to get the whell off put some "copper" grease on the part of the wheel where it locates on the hub, a little grease on the wheel bolts is a good idea too.
    Shetland
    Default copper slip
    Pick up some copper slip ( anti squeal paste ) from motor-store, put a little on each bolt and some on hub face. that should sort you out.
    Engine : 1.9 CDTi
    Have you got it off yet?
    If not put 2 wheel bolts back on but loose and kick the tyre side to side to 'rock' it off.
    Once its off use some sand paper on the hub and inside of the wheel. When your ready to refit the wheel put some copperslip around the hub and where the wheel meets the hub.
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Rubber mallet works every time, like said give it a whack... Hit 12, 6, 3, 9. should pop lose.
    Mileage : 000
    Found this "old thread". Worth a look.
    http://www.vectra-c.com/forum/showth...t=stuck+wheels
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    use copper slip on face as above but not on wheel bolts,or bolt taper,
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Quote Originally Posted by lee gsi View Post
    except the sandpaper idea. this'll only encourage further corrosion, despite the copperslip, as you'll wear through the lacquer, allowing the salt over the winter to do its thing, making your problem worse.
  1. stuck locking wheel nut
    By andy_richmond in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2012, 13:29
  2. Got Stuck!
    By DarylAAS in forum General Chat
    Last Post: 29th November 2010, 15:41
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. HELP, stuck on A14 18:55 12.05.09
    By chrisf70 in forum Engine & Drivetrain
    Last Post: 15th June 2009, 16:28
  5. I had a sterring wheel stuck in my pants this week.......
    By RSV_Ecosse in forum Comedy & Humour
    Last Post: 19th December 2006, 23:56
