Results 1 to 10 of 15
Thread: 2.0 T Sport CAT
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    Default 2.0 T Sport CAT
    Hi folks following on from my map session when they ran the initial diagnostic they said my emissions were slightly high and it was prob due to my CAT being bunged up a bit. I do mostly short journeys so can see how that might be.
    Guy said for me top open her up when I can to clean it out and then give her a good revving etc prior to map.
    Just wondering if when I get my exhaust done should I get sport cat etc? Or are these cars pre catted in which case I'll get rid of it.
    If so where can I get one or would MIJ sort it?
    If so any idea where I can pick one up? Would MIJ sort it?
    Any help appreciated.
    Jul 2010
    west mids
    Jul 2010
    west mids
    Courtenay Motorsport 200 CEL weldin sport cat £245
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Your cast is just below your turbo so you cannot just weld one in. You will need a new downpipe that comprises the cat.
    Best to get a new 3 inch downpipe with either a 100 or 200cpi sportcat. But these cost £500 to make and fit. Anything else is a waste of time and money.
    Search on z20net downpipe and you will find what has been posted on this already.
    Jul 2010
    west mids
    It's none essential at mo so just looking at options
    WGAF#5
    why not take it for a long run to get it nice and hot and then decoke it
    Jul 2010
    west mids
    What does that entail sorry?!
    WGAF#5
    if your only doing short runs then the CAT is not getting sufficiently hot which means that the carbons are not getting burnt off you could take it on a long run which MAY help burn off some of the deposits or take the cat off and manually decoke it but you run a higher risk of damaging it this way
    we see some cars through work that have higher emissions due to clogged catalysts (cars mainly used for short journeys that havent got hot enough) - a good hard burn sometimes reduces the results recorded other times dependant on the level entailed the damage has already been done
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Take it for a long hard thrashing, try adding something like cata clean or similar too
    Jul 2010
    west mids
    Ok boot it I shall n see what happens at MOT.
    I will drive longer way to work to lol that way car is fully up to temp.
    Will check out halfrauds for additives also although I'm on v power already.
  1. sport cat
    By leedslads in forum Petrol Engine related
    Last Post: 23rd December 2011, 10:31
  2. Replies: 3
    Last Post: 2nd November 2010, 17:58
  3. Replies: 1
    Last Post: 25th September 2009, 22:59
  4. Sport?
    By keith1983 in forum Styling
    Last Post: 4th January 2009, 23:45
  5. bmw 330d m-sport
    By mike houston in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2007, 00:52
