Results 1 to 10 of 11
Thread: hid's fitted
    Regular Member ant6566's Avatar
    gwent
    Talking hid's fitted
    just fitted the hid direct kit & sidelights.bit fiddly but took about hour and a half,just waiting for it to get dark,but even in daylight you can see the difference.thanks to felixx for your help
    Regular Member Psykadelik's Avatar
    London
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I wasted half a tank testing mine after fitting them, you wont be disappointed
    Take some allen keys with you too, you can adjust the headlights a little higher. Makes them miles more effective...
    stockport
    Arrow
    Quote Originally Posted by ant6566 View Post
    I'm glad you managed to get them fitted.I know it looks daunting but well worth the fiddling about in the end.YOU WILL notice the difference tonight,believe me. FELIXX.
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    i was told by a parts bloke at a WJ king garage that you shouldn't fit HID's unless you change the wiring loom at the front of the car as they put a lot more pressure on it all is that true ? also what about headlamp washers ive been told you have to have them for it to be road legal and the same with auto levelling
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Aparently its only if the car is fitted with factory fit xenons that headlamp washers/self levelling is required. Alot of members have had MOT's and passed with no problems with the HID's
    As for extra load, HID's actually use less power than standard bulbs. The only time they use more is to ignite them
    stockport
    Exclamation
    Perhaps you can help me with a problem regarding this issue.I fitted a pair to a Vectra B today and found that after about an hour both H/lights went out.When I checked the connections etc,I burned my fingers on the ballasts!!.They started up again no trouble when switched on but there has got to be a serious issue here don't you think?.FELIXX.
    Sodding Typical on Sea
    Sounds a very odd problem indeed??? is it both at one time or is one failing?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by felixx View Post
    Definatly sounds like a dodgy kit, have you tried it on your Vec?
    stockport
    Exclamation
    No way!!.It was a cheep kit I bought off eBay for spares,if you know what I mean,but with his Vectra B having no OBC,I thought I would fit it as a favour.Now to answer your question,BOTH headlight stopped working but came back on when switched on again,(although I then turned them off until the ballasts had cooled down).It would seem as though this is a safety thing but just imagine doing a night drive and your headlights going out after an hour!!.What a brown trouser moment that would be.Anyway,Ive emailed the jerks in China who I bought the kits off,(yes I bought two),so you never know,I might get something out of it from them,one can but live in hope.FELIXX.
  1. HID's Fitted
    By Chris SRi in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 14:51
  2. HID's fitted
    By paul_sri150 in forum Styling
    Last Post: 28th November 2010, 08:54
  3. HiD's now fitted
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 19:14
  4. HID'S fitted
    By bigmac in forum Styling
    Last Post: 1st February 2009, 13:28
  5. hid's fitted
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 11:29
