Thread: plz need a littel help with this
    Regular Member llcoolr's Avatar
    Aug 2009
    ALGERIA
    Question plz need a littel help with this
    plz need a littel help with this cos the winter is comming and realy need to see behind me
    B0283 - Rear Window Heater Low Voltage or Circuit Open
    how to access and get to the wires and fix this problem
    already checked the 40A fuse and it's ok
    model vectra c 2.0dti y20dth year 2007
    Regular Member Dazzy2006's Avatar
    Notts
    open the boot and remove the plastic trims and fabric area on the tailgate - 2x torx screws,4x plastic caps that prise off with a screwdriver and 4 more plastic screws that fasten the warning triangle holder on.Then its a case og just pulling it off as its on those plastic poppers
    Once its all removed you will see the wires running from the center of the heated rear screen on both sides.
    If its not a loose connection then you probably have a break in the heater element
    Are you sure its a 2007 2.0dti as i didnt think they made dti's on the 2007 model?
    EVERYWHERE
    Quote Originally Posted by Dazzy2006 View Post
    It's owner seems to be based in Algeria. Maybe they were still using the DTI engines in that part of the world back in 07?
    Notts
    Quote Originally Posted by diesel dog View Post
    That clears that one up. cheers
    Aug 2009
    ALGERIA
    sir can u explain for me
    what's the problem with the DTI ?????
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    over here the DTI engine was phased out in 2004/2005 on the vectra and replaced with the CDTi' engine which offer much better power/torque/performance albeit with its own set of common problems.
    Notts
    Quote Originally Posted by llcoolr View Post
    I wasnt saying there was a problem with the dti (i hope there isnt a problem as i have a dti), as plasma says over here the dti was replaced by the cdti and i thought it odd when you put 2007 2.0dti
