Thread: ecotec rattle
    Oct 2010
    aberdeenshire
    Default ecotec rattle
    hi everyone this is my first post.
    my 07 plate vectra petrol 1.8 ecotec has had a rattle on start up for ages till the oil got up to the top end. but now it rattles all the time on tick over. I think I may have jumped the gun and ripped it to bits to do the hydraulic tappets but it would appear there isn't any fitted to this engine just buckets placed over the valves. could it be the pulleys that are rattling(vvt ?). not sure when you hold the inlet cam pulley and shake it it rattles but the exhaust one doesn't any ideas people ????? some advice on cam timing would be great aswell. locking cams etc. finding proper TDC. etc. thanks stuart
    Oct 2010
    aberdeenshire
    brilliant stuff guys thanks for all the speedy replies and all your advice !!!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    maybe scotch mist under bonnet ?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    WoW thats a bit unfair. A lack of replies means that maybe no one knows, better to get no replies than a pile of useless ones.
    When was the last time it had an oil and filter change? Maybe the oil is worn out. What grade of oil do you use? Have you concidered using a thicker grade of oil to see if that helps, sometimes the cheaper options are the best place to start.
    Oct 2010
    aberdeenshire
    well as it happens I've actually found the problem out it was intact the cam pulleys that are rattling. they are the ones that are variable valve timing ones they are fed with oil through an oil gallery on the cam. seemingly it's a common fault on the ecotec 1.8 xer engine. £315 for them both. and I've also found out there is two tools needed for setting the valve timing. one to hold the cams in place and one to hold the pulleys to allow to tighten up the bolts so they don't move as there is no woodruf keys to hold them on place. surprised that nobody knew this as this is the uk's leading vectra owners forum.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by stu-mk2 View Post
    Time of post 06:25 on a Saturday. Yea there's loads of us up at that time searching the forums.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If posted in the evening you'd probably have gotten a reply.
    I could have told you that there is a problem on the VVT engine much as you described but this is the first i've seen this thread.
    Blantyre
    My 2.2 has developed a slight rattle , goes to a network garage fromwarranty direct on Friday, i have everything crossed its not the chain just notjust now
  1. vectra c 1.8 ecotec
    By Rob099 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2012, 22:53
  2. 1.6 16v ecotec question...
    By wrayballs10 in forum Engine & Drivetrain
    Last Post: 27th July 2011, 21:08
  3. 1.6 Ecotec 16valve
    By Derek Mc in forum The 'Off Topic' room
    Last Post: 13th October 2010, 19:15
  4. Anyone know what ECOTEC stands for?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 22:20
  5. ecotec and vxl stickers
    By Morephun in forum Styling
    Last Post: 25th February 2009, 22:23
engine rattle on vectra c 1.8 ecotec
ecotec vvt rattle
2.2 ecotec rattle
cams rattling on 2.2 ecotec
vauxhall vectra facelift 2.2 tappet rattle problem
