Thread: which coolant ??
    Doncaster
    Default which coolant ??
    Sorry if this has alredy been covered but i cant seem to find the answer.
    I have a 19 CDTI 120 vectra.
    Im not sure which coolant i should be using ?
    I've been told i should use the red/orange antifreeze but i'd rather ask you guys to make sure ?
    I'm also worried as looking at the expansion tank, the water looks a little orange-y brown and there is what looks like rainbow-y residue on top of the water. i've checked the oil via dip stick and filler cap and there is no sludge or milky oil.
    i'm hoping the water is just a little miss-coloured and needs a flush due to maybe running it with no antifreeze ?
    Full Member Big Sig's Avatar
    Yes only use the longlife stuff - the pink or orange stuff. Why do you think there is or its been running on no antifreeze?
    Regular Member viperone's Avatar
    Aug 2010
    Amersham
    Pink would be best. Mind that if you have anything different in the system already than you can't mix them - will have to drain it completely before putting a new one( unless the same colour)
    Doncaster
    It may already have the pink or orange stuff in as the water in the expansion tank is a orange sort of colour but the reason im concerned is it seems to have gotten darker over the last few weeks. I could be imagining things and getting a little paranoid after someone mentioned my head gasket could be on the way out.
    Aug 2010
    Amersham
    If the gasket might be the case you should see stuff floating in the coolant and some residue on caps both oil cap and coolant bottle. Oil cap stuff will be kind of milky. You would notice a drop in the coolant. Ever had to top it up???
    Coolant will get darker with time. It's not going to be like new all the time.
    Doncaster
    I just had someone have a look for me and they said all the same things you're saying and then he tasted the water lol, after that he said there is defiantely antifreeze in. All the other stuff is fine so its just me being paranoid. Thanks for your time tho guys...
    Aug 2010
    Amersham
    It's always good to top it up for winter with just the concentrate so it holds better on freezing days.
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. coolant going somewhere
    By pud wayman in forum Diesel Engine related
    Last Post: 28th March 2012, 08:59
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
