Thread: WIll these alloys fit?
    redditch
    Default WIll these alloys fit?
    I have been thinking about adding some alloys to my vectra as i only got steel ones when i bought it last year and have been offered some 17'' for only £100 with tyres they are ripspeed and the size is 205/40/17. will these fit my vectra as i am not that clued up on alloy's??.
    The one's i have on there at the moment are 215/55/16 and have been told that the alloy's that are available are a 5 stud universal fit.
    Help please.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Your gonna need to find out the offset, the PCD (i.e 5x110mm as the Vectra is) also the centre bore size as well.
    Profile of the tyre is too small, you need either 50 or 45 profile on 17's.
    Sodding Typical on Sea
    You need to know the stud pattern you are after 5 x 110mm pitch and an offset of about 39>45mm on a 17" rim the tyre size you need is 215/50 x 17 (or 225/45 x 17) the size you describe sounds like those off a Vectra B and will severely upset the gearing and speedo reading. a 205/40 will be too small a rolling diameter I am sorry to say
    redditch
    Thanks for the reply guy's, is there any way i can put them on like adding spacers or is the profile to small.
    You need four new tyres, if and it's a big if the bolt mounting centres is correct and the centre hub is the correct size as well.
    so buying them blind would be a major expensive risk
    Spacers would not really help in this,
  1. XP2 Alloys
    By matt_hilluk in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 07:39
  2. alloys
    By skippyroo in forum Insignia car chat
    Last Post: 25th September 2010, 19:24
  3. what alloys are these?
    By Hendry02 in forum Styling
    Last Post: 23rd June 2010, 22:35
  4. alloys
    By rich32 in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2007, 22:35
