Thread: pw the engine bay
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default pw the engine bay
    Hi boys i clean my engine bay every week with cleaner yet ive never used a pressure washer on it which id love to do to get to bits i cant get to.. im just looking to see if i can get some advice on if its safe to do so on a vectra if so do i need to wrap up any connections thanks everyone
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    one word dont do it makes everything rusty
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I did mine a couple of weeks back with no problems. You can wrap the electrical components up but IMO there no need to as long as you don't directly blast them at close proximity. The electrical components under the bonnet are designed to get wet to a certain degree, splashing from deep puddles, condensation from cold and heat etc....... The answer is a good degreaser and a stiff brush then you shouldn't need to go hell for leather with a pressure washer. I always make sure the engine is heated up when I do it to help dry off any water a bit quicker, just avoid directly power washing the exhaust manifold. I use Auto Glym Engine and Machine Cleaner on mine, does a great job.
    bridgend / wales
    great advice thanks mate
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
