Results 1 to 10 of 11
Thread: Headlight housing misting
    Sodding Typical on Sea
    Default Headlight housing misting
    Anyone else getting misting inside the lenses? I fitted the HID's and made as sure as anyone can that the rubber grommet sealed into the casing for the low beam but after a really wet few days (no use of the lights however) I have misting in the outer corners covering about 15% of the lens area
    Regular Member Dan.'s Avatar
    milton keynes
    any pics of of the lense fella
    Regular Member vectraboyy's Avatar
    Quote Originally Posted by Derek Mc View Post
    I get that two, im thinking of going and buying some new backs, redrilling, and then siliconing, its blimin annoying!
    Quote Originally Posted by Dan:) View Post
    Nah not at the moment they had almost dried out when I did go out to photo them so I suspect there is a link to the xenon's for the moment and might need to add a liquid gasket to the grommet?
    Regular Member paul.sessions's Avatar
    leighton buzzard
    i get the same prob too with hids
    Mmmm OK I think I know what to do will get a plasto-rubber gasket and see what happens
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i get this too and thought it was because the hid's didnt generate the same heat as normal bulbs
    The funny thing is in the days I ran Bimmer's they advised drilling a small hole in the housing to let it breathe, we have cut a hole in the sealed backing cap and plugged it with a rubber grommet so not really made a massive difference I would have said.
    As for the heat yes the old Halogens are a good heat source for sure the xenons get warm but warm in a florescent type way so there isn't the same opportunity to dry them out I guess?
    Bloomin annoyong anyways
    stockport
    Arrow
    The same has happened to my n/s one,but I have put it down to the fact that I cut too big a hole in the rubber cover.Keithy kindly let me have a extra pair he had so I'm going to use one of them and see how it goes.If not it's plan B,in that my son has a Vectra B with solid covers,so I'm going to nick his and swap them over if it doesn't work!!!!(who said all dad's are barstewards)?.FELIXX.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i had the same with the hids fitted ...just get some silicon gel bags in there ...that sorts it out
  1. Headlight misting up
    By trickydickySRI in forum Bodywork & Interior
    Last Post: 7th September 2011, 12:06
  2. anyone know if the headlight assembly housing / lens can be split ?
    By Rocky Balboa in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 18:16
  3. Found a cure to Headlight Misting up
    Last Post: 26th February 2007, 21:18
  4. Misting Up
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2005, 22:18
