Thread: changing the gear knob
    Oct 2010
    south shields
    Default changing the gear knob
    alright, just got a gearnob from the scrap yard as mines all worn, does the actual knob bit screw off or do you have to take the full stick out with the 2 ball joint bits?
    Sodding Typical on Sea
    The full unit needs to come out. I think there maybe a how2 on here for that job
    Oct 2010
    south shields
    ive had a good look but nothing seems 2 be very helpful lol
    Regular Member Dan.'s Avatar
    milton keynes
    mine just pulls off lol
    Regular Member Sparky67's Avatar
    West Mids
    Quote Originally Posted by jamie_hepp View Post
    My gear knob came off in my hand last week it had been loose for a while. It's on splines so should be possible to knock it upwards and off if you can get something in the gap between it and the reverse gate override. Watch the reverse gate spring doesn't jump out when it comes off and disappear somewhere inaccessible though - it's just slid over the stick under the knob !! Good luck...
    exeter
    if its a dti you need to take the rear and front console it sounds alot but it takes about 1 hour . start off by taking the ashtray or the cover by the vents off then inside you will see 2 screws and 4 bolts holding the vents on undo the lot and remove the front cup holder there is a screw undo the rear should come away and the front console remove ashtray and trim around the gaiterand unclip. then take the trim off below the centre vents and the are 2 screws and on the sides by the footwell there are 2 covers on each side remove and undo and wher the cup holder was their is 1 screw remove thats the console done then 4 bolts that hold the gear cradle on and gentle unclip the cables with a flat screw driver and it comes away . do it in reverse to put back.
    Full Member
    South West
    Is the dti really that different from other Vec c's?
    I got the gear stick out of mine by removing ashtray, the gaitor, 4 screws on the cradle, and popping the ball joint to the linkage. 5 min job.
    I gave up trying to get the knob off for fear of damaging it
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    old school dti's utilize a different type of gearstick assembly so to remove it is a nutache... But the gearknob itself I imagine comes off the same way.....
    exeter
    aidi yeah the stick is fixed in the cradle which is about 10 inches long and as wide as the centre console which unbolts off the centre of the car . but first both front and rear console has to be removed
    exeter
    plasma yeah it does but i took some bad advice on hear and un pop the joints which broke the cups that it sits in so i . had to replace the whole thing , cdti and dti are so different
  1. Changing over insert on gear knob
    By aerodynamic18 in forum Bodywork & Interior
    Last Post: 28th August 2011, 10:23
  2. Changing Auto Gear-Knob
    By SamT in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 09:53
  3. Changing gear knob on pre-face lift sri...
    By PAULMAC77 in forum Styling
    Last Post: 10th March 2009, 17:29
  4. Changing gear knob on pre-face lift sri...
    Last Post: 10th March 2009, 17:00
  5. changing my gear knob...
    Last Post: 8th March 2009, 12:52
