Thread: 2.0 DTi tries to go to limp mode
    Regular Member viperone's Avatar
    Aug 2010
    Amersham
    Default 2.0 DTi tries to go to limp mode
    My Veccy started presenting a weird behaviour.
    When I drive and try to accelerate quickly - reed floor it - no matter which gear I'm in, at around 2.5 -3 k revs the spanner light pops in to the screen and I can feel the engine goes in to a limp mode but just for a second or two then it keeps accelerating in a normal way and after 3-5 sec. the Spanner light disappear.
    If I use the acceleration pedal gently that never happens .
    Any idea what that might be.
    No fault codes found with diagnostic software
    north east
    Had that problem on my 2.0 dti astra mk4 it was the crank shaft sensor ... well i didnt know that at the time but 3 / 4 weeks later it was just perminantly in limp mode.
    Regular Member vectraboyy's Avatar
    Quote Originally Posted by viperone View Post
    Oo, i had a similar problem with my astra 2.0dti - twice.
    The first time it was just the EGR on its way out.
    Aug 2010
    Amersham
    Quote Originally Posted by roswell View Post
    Did replacing the sensor solved the problem ????
    Aug 2010
    Amersham
    OK Cleaned the EGR today and no major difference in behaviour. Will get the Cam Shaft sensor.
    Anyone knows where it is located on 2.0 DTi
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Cam shaft sensor is underneath the oil filter at the front of the engine , but i think you are looking in the wrong place for your limp mode fault
    Aug 2010
    Amersham
    Quote Originally Posted by bobssignum View Post
    Well it's not like it does go in to the limp mode. Car judders a bit and than it keeps going normal. It never happens with gentle acceleration.
    You've got any other ideas ????
    Look at the EGR...
    Your showing the same symptons as i had on my 2.0DTi, it gradually gets worse.
    Engine : 2.0DTi
    Mileage : 73350
    TP Sensor on the throttle body on its way out, or the boost sensor needing cleaning, also check your vacuum hoses for cracking around the connectors. to be certain best to have the car tech 2 ed and see what fault codes are produced, that is the only sure way to diagnose it.
    Aug 2010
    Amersham
    Vacuum hoses checked when bought the car - got it VERY cheap thanks to that - no splits now. Boost sensor cleaned about 3 weeks ago, diagnostics did popped in with this
    P0340 - Camshaft Position Sensor Circuit Range/Performance
    but only once and now gone.
    Also cleaned the EGR today - bit more response but still same behaviour
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
