Results 1 to 10 of 11
Thread: Bulbs
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default Bulbs
    What type of bulb fits into the indicators of a facelift C and is possible to fit LED style replacements?
    Full Member Big Sig's Avatar
    If you fit led replacements be prepared for them to flash dimly when the car is off and for you to have loads of bulb failure warnings.
    Regular Member G4GAV's Avatar
    Bristol
    funny that , i found that out the other night when i fitted them in to my number plate light holders.
    but why does it do that ?
    Its due to the pulsing from the canbus bulb failure checking system iirc.
    Bristol
    damn, i like the white light look, not the yellowish one
    Limavady, N.I
    Mileage : 121000
    Are they 501's?
    Quote Originally Posted by G4GAV View Post
    not sure if you can get ones with a resistor in to stop that or not. Maybe have a look for them?
    Quote Originally Posted by rmg1 View Post
    Are they 501's?
    No thats the side lights. which if you fit the wrong led's in those your car will use the indicators on a dim setting in their place.
    Regular Member fingers66's Avatar
    Carpe Diem
    I have leds in my number plate light, they dont flash
    Limavady, N.I
    Mileage : 121000
    So what goes into the indicator then? I want to get some before I remove the light unit as it dosen't tell you in the handbook.
    Bristol
    Quote Originally Posted by fingers66 View Post
    only one side flashes on mine, i took them out just in case i came out the following morning to a flat battery
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. 80w bulbs
    By wullie-t27 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 11:00
  4. LED bulbs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 09:47
  5. Bulbs!!!
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2007, 14:22
