Results 1 to 3 of 3
Thread: 2.2 Direct SRi fuel problems...
    Bolton
    confused 2.2 Direct SRi fuel problems...
    Hi All,
    Got a 2.2 SRi with the dreaded fuel problems...
    It starts up fine, but then cuts out after a few seconds. Then it wont start again for a few minutes - then it does it again.
    I replaced the High Pressure Pump but the fault was still there. Starting up as it should but cutting out if left to idle.
    If I disconnect the fuel rail pressure sensor, it will run all day - although the management light and spanner light stay lit.
    Is it likely to be the fuel rail pressure sensor at fault, or could it be something else?
    Thanks in advance....
    Jan 2010
    glasgow
    hi take it the fuel pressure regulator was changed to? as there also a common fault if you have i would change the sensor to and after that its a case of if i didnt fix it its a op-com or tech 2 scan
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    Quote Originally Posted by hoochydady View Post
    Agree with this mate - the fuel pressure regulator is on recall - had mine done a couple of months back. Give your local Vauxhall garage a ring, quote your reg and they'll be able to let you know if yours is one within the group that needs replacing.
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. 2.2 Direct problems
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 19th January 2012, 19:07
  3. 2.2 Direct SRi - Fuel Problems.
    By tomtaylor15 in forum Engine & Drivetrain
    Last Post: 24th September 2011, 05:52
  4. 2.2i direct fuel pump / regulator problems
    By alanatrr in forum Engine & Drivetrain
    Last Post: 19th January 2009, 21:37
  5. 2.2 direct sri problems
    By 22sri in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 14:37
