Results 1 to 3 of 3
Thread: glfcglen
    Oct 2010
    northern ireland
    confused glfcglen
    My vectra has shown fault 2279 intake air system leak and is not starting now at[RIGHT][RIGHT][LIST=1]
    all can any one help please?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Need a bit more info here, what engine is in it? Could be a hose has split or worked lose. Failing that, unplug the MAF sensor from the airbox, see if it starts up then.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    This relates to the difference in readings from the maf sensor (the 1 right by the air filter) and the boost sensor pressure (the 1 on the back of the inlet manifold), I would go for the EGR, manifold-throttle body, worn or complete failure of the inlet manifold, or swirl actuator motor, Although i would expect it to start, So try removing the EGR first! there's a guide in the 'how 2' section on this site, remove & clean the EGR & BOOST SENSOR, THEN DO THE THROTTLE BODY, important though is that these are done with carb cleaner and do them well!,do a FULL clean of the EGR including stripping the elec solenoid from it & cleaning, the guide does say lubricate with grease but i WOULDN'T advise this due to very cold conditions can cause the moving parts to stick, use elec contact spray or rust inihibator. there's a guide for all 3 here.
    http://www.vectra-c.com/forum/showthread.php?t=70471
