Thread: GM Diagnostic Fault/Trouble Codes
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Exclamation GM Diagnostic Fault/Trouble Codes
    On a wee search I found the following link:
    GM Motor Group Diagnostic Trouble Codes
    Sorry if this is a repost.
    Hope it helps.
    Gazza4
    Regular Member LADmachining's Avatar
    Hampshire
    Be aware that these are generic codes, and not specific to a particular vehicle / engine control system.
    As such, some of the codes are not correct.
    For example:-
    P0650 MIL Control Circuit Error according to the list.
    For the Z19DT(H), for example, P0650 = CAN - No communication with CIM (Steering Column Module).
    The majority of the codes will be OK, but be aware of the anomalies.
    Nov 2010
    Paisley
    Default can anyone help
    I recently bought a Vectra (54) 2.2 sri on Tuesday night I drove the car home as usual from work, Tuesday night was cold but not to cold, when I got up in the morning my car wouldn't start,the engine wasn't turning over or trying to fire up just a kind off whirring noise, so I tried some jump leads and wouldn't I got the A.A guy to look at it, at first he thought it was the timing chain, then he change his mind thinking it was either the fuel pump or fuel intake pipe, I took it to a vat registered independent Garage and he told me that he thins it might be the coil sensor or my timing chain, but his machine wasn't recognizing the code, hes know advised me to take it to a Vauxhall garage as he can't be sure of what is wrong with it?,
    Has any one had these problems before?, can anyone give me insight what it might be?
    Or advise me of what i should do next?!
    Jan 2010
    glasgow
    hi mate the 2.2 is well known for the chain to go its allso well known for the fuel pump and regulator to go, if its a wirr noise wen your trying to start it are you deffo sure the starter is ok? poss sounds as if the chain is gone see wen your try to start it is it making a fast wirr sound rather than a normal sound of a engine cranking over if so its a good chance your chain has went and you have prob bent a few valves to
  1. Loads of trouble codes - help!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 7th December 2011, 23:58
  2. please help!!!!!!!!! diagnostic trouble
    By mickynoakes in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 22:28
  3. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
  4. Vectra 2.6 Diagnostic codes P0170 & P0173 Found
    By hairyone in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2009, 11:21
  5. Trouble Codes-Need HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2009, 16:43
