Results 1 to 10 of 19
Thread: Interior Light
    Oct 2010
    Lincoln
    Default Interior Light
    Thinking of changing the interior light in my Sri for the one with the reading lamps. First of all would this be a straight swap? Phoned the local dealer who tells me that although they have them, they are only for fitting into Police cars and he reckons you can get pulled over if you use the reading lights while on the move??
    Any thoughts?
    Sodding Typical on Sea
    Mine has map lights built in plus the sunglasses holder the Police spec ones have a fourth button AFAIK that will turn them off tis the only difference.
    Dunstable
    I've got the 4 button one in mine mate. Straight swap. Prize off the plastic cover that overs the light bulbs, there are 3 torx screws to undo, and the clips at the side. Undo the plug, plug into the new interior light and refit. Simple As for only allowing the police to have them, that's absolute rubbish. Most higher spec cars have them as standard and are a recognised part. Fit it and think no more of it
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Only if you want the buttons to be illuminated if they are not you either have to take power to them from other place.. or fit new roofloom..
    Oct 2010
    Lincoln
    Thanks, that's what I thought as well. All I've got to do now is get him to sell it to me
    Dunstable
    Quote Originally Posted by kenp View Post
    I went from a 1 button interior light to the 4 button one in my 06 SRi, straight swap and everything works fine, no need to modify the loom at all...plug and play
    Oct 2010
    Lincoln
    Sounds good, I've got a 56 plate Sri with the single switch. Where did you get the 4 button one from?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    i have the 4 button one came with car
    Wales, UK
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item5195f0d132
    I think a little overpriced but check Ebay out..
    Quote Originally Posted by lencuff View Post
    go on ebay probably a lot cheaper too
  1. interior light
    By jamiedvvt in forum Bodywork & Interior
    Last Post: 19th November 2012, 17:47
  2. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  3. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  4. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  5. interior light
    By chrosty in forum Bodywork & Interior
    Last Post: 6th April 2011, 23:06
